A couple months ago got rid of CABLE and installed a 'window antenna' ... I get 17 local channels ... few days ago while making adjustments to picture/sound, channels aligned themselves in numeric order without spaces in between; all of a sudden unable to VIEW shows listed under that NETWORK; only shows channel letters; would still accept timed shows, but stopped switching to scheduled shows. is problem with TV or the remote??? how to fix.
SOURCE: picture blacked out
Your Close Caption is turned on. Search in your menu for Captions, and turn it off.
SOURCE: tv set just lost its ability to display digital channels
Your problem is definitely the input signal source to your tv. It is extremely rare where a new tv has a tuner signal sensitivity problem. The best thing to do is to replace your current set of rabbit ears with a different set of powered rabbit ears that have a higher gain rating with a variable gain control. Please note that the gain control setting is critical when setting up your tuner for auto-programming. If the gain control is set too low or too high it will result in your symptom.
If you still can't get it to work you could try buying a line amplifier which you would install to the rabbit ears before the tv. If you still can't get it to work you'll have no choice but to purchase an outside antennae as a result of your being in a weak signal area as signal quality changes by such things as the switch over to digital upcoming and environmental changes.
SOURCE: Sound on one channel from over the air antenna has suddenly become garbled. All others are fine.
If only one channel is affected it is not a problem usually with the set--it does not know what channel you are on---look in audio menu and make sure if set has SAP it is not on.
