Question about Photography
How do I get the film from the small pin from my dash cam
    New Friend:
The pin is normally a reset button. Your recordings should all be saved onto a small tft card which should secure itself into the cam by pressing it from the end until it 'clicks'. Removal is the opposite, so press it again and it should 'click' out
Posted on May 02, 2019
SOURCE:
I have changed fuser film canon 2520 and got error E000000 and than i tried clear but not cleaning
Itsca heater element failure code.please chech heater element.generally when we replace fuser film the small two pin connector on front side is disconnected.may be you forgot to put it back.
Sep 28, 2018 | Canon Office Equipment & Supplies
I have a Pentax Spotmatic F Camera. When I depress the rewind pin, it does not remain depressed. I must hold the pin in and rewind the film.
Tony your camera is now over 30 years old. THe fact that this is all that is wrong with it is a blessing. But why are you still shooting film? There is nothing you can do on film that can not be achieved on digital.
Dec 19, 2017 | Pentax Cameras
My windshield gets a film which seems to smear after cleaning
This is most likely smoke if you or someone else that drives it is a smoker. There is a small chance that the plastic dash is outgassing and causing this.. The dealer has something you can put on the dash to help slow that down.
Jun 24, 2011 | 1998 Mercury Villager
I have done engine overhall for my mazda 6 2003.i want to know how set timing and the timing marks?
there are special tools pin to lock crank in correct position and cams have flat plate that goes across into both at rear of cams small section goes up from memory, the cam gears have no dowel pin/locating pin to camshaft you do bolts up last when all are locked in position and grenade pin (locking)pin in tensioner is removed and chain is tight then hold cams with shifter or spanner(wrench) on cam flats and do up cam gear to camshaft bolts on each cam.
hole in front cover just above crank pulley at 11O clock, blind blanking plug must be removed to put in chain tensioner pin, crank blanking plug on your left side when looking at crank pulley(side of block) remove and locking pin goes into there when at TDC no1. and cams should be in position to lock with plate as described above.may not be any timming marks on chains or gears due to the locking tools needed and relied on for correct position.
good luck if you feel confident.
some Mazda dealerships may lend tools if you ask nicely or know some one.
Mar 10, 2011 | 2003 Mazda Mazda6
My cam was working fine. The film got over and I decided to load a new one. Once I did that and switched on my cam. The cam displays an error sign...??
The film may not be feeding to the take up spool properly. If that is so, there should be flashing symbol something like this: O_ _ _ _ . If that is the error you are seeig , open the back and re-insert your film. You may lose a couple of frames.
Oct 17, 2009 | Nikon F75 35mm SLR Camera
The picture on my Vizio 42" flat screen suddenly shifted to a whitish pale color with ghostly looking images that look like negative film.
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
Aug 04, 2009 | Vizio VO42L 42 in. LCD TV
Don't know how to take off the manual film crank
If I remember correctly you pull out the pin that the crank swivels on.
Apr 25, 2009 | Bronica ETR-Si Medium Format Camera
Pentax 145M has lost data from LCD panel
Open film door.
There should be small CR2025 battery in the film door.
Mar 04, 2009 | Pentax IQZoom 145M 35mm Point and Shoot...
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
Photography Logo
Top Photography Experts
Steve Allison
Steve Allison
Ric Donato
Are you a Photography Expert? Answer questions, earn points and help others
