Hello Eric, you should be able to disable the energy saving of your Philips by entering the menu, then choose Picture, then select, Auto Picture and from there enter and select Energy Saving, where you can change the status and achieve greater clarity, all these steps are indicated in the user manual, page 31
I sent you the link to download the user manual
I hope my comment has served you
Greetings Franco Dosil
Hola Eric, deberias poder deshabilitar el ahorro de energia de tu Philips entrando en el menu, ahi elegir Picture, despues selecionar, Auto Picture y de ahi entrar y selecionar Energy Saving, donde puedes cambiar el estado y lograr mayor claridad, todos estos pasos estan indicados en el manual de usuario, pagina 31
Te envio el link para que descargues el manual de usuario
espero te haya servido mi comentario
Saludos Franco Dosil
https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_aen.pdf
https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_lsp.pdf https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_lsp.pdf
SOURCE: Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
SOURCE: how to temporarely disable analogue power saving mode
Go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
SOURCE: Disabling Power Save mode
If you enter the config menu, you can turn off energy conserve. You enter the config menu by turning off the printer, holding the center and right arrow, and powering the printer on. Continue to hold the buttons until you see Performing self test. Then you will see config menu. If you scroll down to energy conserve and select it. You can change the option to off. This will disable power saver.
