SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
SOURCE: shower pressure.
Hi chicken69
I'm Harvey the Master Plumber.
You want to know why the presssure on your triton t80i shower has dropped by half?
It is very possible that some debrie has come up in the water and is partially clogging the shower. For this you would have to turn the water off and dissassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Intermitent heat from Atwood 10 gal marine water heater
Water level safety shutting down heat source
SOURCE: 1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
SOURCE: I have a Kohler K-7 steam generator/shower and
There is a float valve interior of the steam generator that supplies water to the generator unit. There are no parts available for that unit, and Kohler was useless re: repair. I have the same unit and mine is doing the same thing. I took it apart and there is a washer worth about a nickel that is inside the unit. I flipped the washer over in mine and it worked for about a week....then back to the same problem.
