Question about Camping, Backpacking & Hiking
Light switch on lantern will not stay in ON position when pressed
    Top Expert:
  • 54,195 Answers
The switch is defective.
Posted on May 02, 2019
2 Suggested Answers
SOURCE:
efs_perpends
  • 1996 Answers
SOURCE: lantern taken out of 5
I don't like to be the bearer of bad news, but it looks like there are no longer replacement batteries available for that lantern. Please see this link for repair parts from coleman. (also possibly here.) There is a customer service number listed at the bottom of that first page that will put you in touch with a Coleman representative, who may be able to suggest an alternative choice for your lantern. Failing that, the only solution I can recommend would be to take the lantern to one of the aftermarket battery suppliers (such as Batterys Plus, etc.) and see if they can provide you with a non OEM version of the battery you need for your lantern to take a charge.
Good luck. I hope you're able to find something.]
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jan 10, 2011
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
I received a 21 LED lantern for Christmas and got the 3 "D" batteries and the thing glows at what should be shut off point. They only way to shut it off is to remove the bottom plate. Is this normal
Turn clockwise and counter clockwise the lantern.(The upper side leds)
If not check the pin of switch that makes the contact to the upside.
Jan 01, 2015 | Ovens
How to fix the switch on eveready lantern flashlight
The switch in the lantern is a press fit switch so you will destroy it when you remove it. Remove the lense and retainer ring. Remove the battery. With a pair of pliers, preferably channel lock water pump pliers crush the switch into small piece and discard. Trail Tech makes the exact water resistant switch model 040-ls-b and you can get it at Amazon or on eBay . The switch runs around $6.25 + $4.00 shipping
Jul 11, 2014 | Energizer Eveready Utility Lantern Uses 6V...
My mom purchased this Jeep lantern and does not have the manual that came with it. I don't know how to get the light to stay on. She uses this to get across the street to get her mail. She is an 82 ye
Hi, I'm having a similar issue with my jeep lantern as well. It's actually a really nice lantern, however, when I plug it in with the power cord, it seems like it is A LOT brighter than when it's just running on batteries alone. When using the turn button, it does get brighter and dimmer, just not to the extent I would like it to be as I use the lantern at night as well to do things such as checking the mail and going to my vehicle. I feel much safer with the light at night, but obviously can't keep it plugged in when walking around my property. It just is not as bright running on just the batteries. I'm not sure if there is a mechanical error with the product, but I've never noticed the difference between the brightness until recently. I changed the batteries and it just didn't make a difference. Just wanting to get some advice to see what I could do to try and make the light brighter. Maybe it has to do with the new batteries I bought, however, they are GREAT batteries I purchased and I don't think that is the issue. Some suggestions would be helpful. :)
Nov 16, 2013 | Jeep Lantern
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Nov 22, 2011 | Camping, Backpacking & Hiking
I have a coleman propane lantern model 5417 that will not light. Does seem to be getting the propane. Appreciate any help or ideas. Thanks, Joe
Clean the hole in the tip of the generator, or turn the wire handle 360 deg. 2 or three times, and try to light the lantern with the wire handle in the down position.
I hope I was some help? Cheers David dwfarrell@gruvy.com
Dec 06, 2010 | Coleman Sport & Outdoor - Others
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Camping, Backpacking & Hiking Logo
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
