About "Hitachi 50V500A cooling fan doesn't turn off",SD tech guy sad it is two fans inside so,I opened back cover and it always work fan for lamp, not for circuit board. What is conclusion? Thank you.
After i replace the lamp on my Hitachi50v500a worked everything then i turn it off.After 1h wanted to turn it on again and it shows (TEMP) light is that a lamp fan or something else.Please help how to fix it by my self.Coz no money to call the tech.
Set has at least 2 fans---if the lamp fan never shuts off you have a real circuit problem
I already fix it myself ! Need to open back cover, and on circuit board where power cord goes ( located on left side if you look from behind TV) it has power relay. Because contact in this relay little burned, that's why power circuit board and fan for lamp still on. Solution: open back cover , remove speaker, remove circuit board,open cover of that relay, clean contacts by fine sandpaper, assemble back and done! I made picture if anyone want it, send email to [email protected].
