Question about Dehumidifiers
My 70 pint keeps filling up the bucket and shutting off, even if I have the pump on - and hose free and clear. I can see some water being pumped out of hose at various short intervals
SOURCE:
  • 30 Answers
SOURCE: Pump not pumping
It's not a one way valve, it's a water strainer. It has a barrel with a fitting on each end, the upper leads into the barrel, the lower has a strainer tube attached. When it's plugging up, it seems like a one-way valve because when you try to force water into the top, it pushes the lint and junk against the strainer screen, blocking it. When you try to force water in from the bottom, the water pushes the lint away from the screen, allowing a reduced flow. Some have an arrow; it's to indicate flow direction to keep the lint on the outside of the screen; the inside, being mush smaller than the barrel, would plug up much sooner. Before you replace the strainer, clean the lint & stuff out of the small pump reservoir (above the pump). If you don't, the strainer will plug up quickly again, if it can even get water to it.
Posted on Aug 31, 2008
  • 288 Answers
SOURCE: Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Posted on Nov 27, 2009
heatman101
  • 43501 Answers
SOURCE: my frigidaire 70 pt
make sure that the hose is not plugged and that it runs continuously flat or downhill... if it is trapped it will not drain...
heatman101
Posted on Apr 23, 2011
  • 4736 Answers
SOURCE: i have a hose discharging water from back . but
The clog is not in the hose. It's in the hose connection tube inside the unit. To unclog it use an 18" long plastic Zip Tie or something similar that is flexible and will fit into the hole. NO wire coat hangers though. Gingerly work it into the hose connection hose, until you reach a bend in the tubing. This is the tricky part, as you have to get past this bend. Be careful and work it past the bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out while rotating it. This will dislodge the clog. Once the Tie is almost all the way out, be prepared for water to follow.
One other thing. If the unit stops operating check that the bucket full light is illuminated. If it is remove the bucket and empty the contents and then check the seal between the hose and the drip tray. If there is a small leak then replace the hose gasket and re-tighten the hose.
FYI - Your humidifier does not have a pump. It relies entirely on gravity to drain, when you use the hose connection.
That should solve the problem.
Posted on May 23, 2011
  • 4736 Answers
SOURCE: My model is Frig. Dehumidifier,
Check the float valve in the top of the bucket. It may be stuck in the UP position. If that the case, jiggle the float valve arm to get it to return to the DOWN position. That should solve the problem.
Posted on Jul 10, 2011
Why is water going to the bucket instead of getting pumped out the hose? Does this mean the pump has quick working?
It is possible that the drain hose is not properly positioned. It is very fussy about that. Here is a link to the manual on PDF. See pages 8 thru 12.
http://www.soleusair.com/Manuals/2013%20Manuals/Dehumidifier/SG-DEH-70EIP-6%20Manual%2012-05-12.pdf
Oct 23, 2015 | Soleus Dehumidifiers
Drains through hose and into bucket
this happens when the drain tube becomes blocked so unit overflows and water falls into bucket and not flows out tube , clean tube and drain port with compressed air (wear eye protection!!!)
Jul 17, 2015 | Keystone KSTAD70B 70 Pints Energy Star...
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
Water doesn't run out the hose when hose connected
make sure the unit is a good deal higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Sep 19, 2012 | Kenmore 70-Pint Dehumidifier
My model is Frig. Dehumidifier, 70 pint. model # LAD704DUL. I hooked up the hose for continuous operation, but the bucket fills up too, even though water is definitely coming out of the hose. It...
Jul 10, 2011 | Frigidaire Dehumidifiers
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
I connected the hose adapter so that I can drain directly into the sink. But it still drains into the bucket. Did I miss a step?
I had the same problem. The plastic tube that routes the water out the back doesn't fit tightly. It took a couple of weeks but the bucket would fill and the darn thing would shut off.
My first attempt was to put a hose clamp over the adapter. The clamp was simple enough but then the bucket wouldn't go back in. Using a small saw, I carefully cut a notch in the bucket. WARNING: Make sure that whatever you cut doesn't reach low enough that when the bucket fills, the little float thingy shuts off the unit before it starts to leak. Anyway, that still leaked. The problem is that that plastic tube is stiff and slippery and doesn't seal well.
What finally worked for me was to take the adapter off, go to the hardware store and buy some clear plastic tubing. I found some that fit very tightly over the tube inside and, with the hose clamp, sealed well.
Problem solved.
Jul 03, 2010 | Maytag M7DH45B2A Dehumidifier
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
Bucket fills instead of going down the drain
You may have an unintentional trap in the line (an up and down up and down. Hose has to lay flat on floor to drain.
Jul 04, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
