This amplifier has 7 tubes in it. How much should this amplifier put out in Wattage. The measured amperage was roughly 11 amps . Does anyone know where this information can be found ? I want to know exactly where to find it, not hunt on the internet. I have looked all over the internet. Thank you
SOURCE: Power Consumption Operational Value?
This is what you want to know. Copy and paste this address.
http://www.voxtechnologies.com/alcatel/pdf/ms2902.pdf
SOURCE: No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
SOURCE: Pioneer 12v car amp rated at 1200 watts max requires ? amp fuse
Hi I would suggest 40A (i know guys will disagree) but you shouldnt be running at full 50A. Fuse are often rate at 50% - 75% of the actual consumption. By the way, 8 guage @40A will give you about a 2% drop at 5 feet. Maybe consider heavier for 40A?? Just a suggestion
SOURCE: Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
SOURCE: I need the exact location of the 1994 cadillac deville radio amp,
a have a cadillc deville concurs 1994 with 180000 km.
the transsmision not shifting gears it run only on first gear.
if there is a recondition fluid to fix the problem to be able to clean the piston switchs insde,
the car location in montreal canada
