Check input or source
Hi Tom, for the failure that you describe, it would seem that you were wrong with the LEDs of the backlighting of the screen or the power supply that supplies power
If you have technical knowledge, I send you the link so you can download the service manual
But, I sent you the link where you can download the user manual, where on your first page are the contacts of Technical Service of Vizio
I hope you find the information I provide useful and you can solve your concern
Greetings Franco Dosil
Hola Tom, por la falla que describes, parecer?a que tuvieras mal los Leds de la retroiluminacion de la pantalla o la fuente de alimentaci?n que le suministra energ?a
Si tienes conocimientos t?cnicos, te env?o el link para que puedas descargar el manual de servicio
Sino, te env?o el link donde puedes descargar el manual de usuario, donde en su primera pagina est?n los contactos de Servicio T?cnico de Vizio
Espero que te resulte ?til la informacion que te brindo y puedas resolver tu inquietud
Saludos Franco Dosil
https://www.electronica-pt.com/esquema/func-download/37483/chk,77c6416dd7f51773a3e94fe02b61bfad/no_html,1
SOURCE: I have a Vizio vw37lhdtv40a and my picture goes in
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help to solve the problem....
SOURCE: 42" Vizio 240Hz SV421XVT no hdmi video or audio
Possible bad source, bad cable or connection was made with units powered up which HDMI does not like.
First thing to try in this case is to remove power from set and whatever unit is connected via HDMI and disconnect the cable itself.
Wait for several minutes, connect HDMI again and THEN return power to the units that were removed from power, this cannot hurt and may help or correct this issue.
Failing this try if possible to connect using component connections.
