SOURCE: The coils keep freezing on my gold star dehumidifier
Try turning the setting down lower in order to help the unit cycle on and off, rather than have to run constantly.
It could be that your situation requires more than one dehumidifier for the space you're trying to cover with this one unit. These units are not designed to operate 24/7 without cycling on and off frequently.
The situation you're experiencing tells me that you have either an extreme amount of moisture where the unit is placed, or the area is much to large for just one unit to handle. If you can issolate the unit to one area by closing a door, etc. if that isn't possible, you'll likely need another dehumidifier to help reduce the load on this one that's freezing up while helping reduce the amount of moisture in the area.
If that doesn't help, please provide more details about the area the unit is being used in and the size of the room, etc., so I can further assist you in solving the problem. Thanks!
SOURCE: icing on back of dehumidifier
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
