It has a clicking sound when you open or close it
SOURCE: HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
SOURCE: motorola razr v3 keypad problem!!
Press all of the buttons and keys on the phone one by one with it powered off and the battery out. Make sure they all feel normal to the touch and when pressed. Check the buttons on either side of the main display carefully, as these tend to get stuck more than others.
SOURCE: Motorola razr v3 display went out
Either your flex cable is broken or came loose. Is the top left hinge button still intact? Is it loose at the hinge? You will need a Torx 4 screwdriver to take the LCD screen apart to check the flex cable inside.
SOURCE: cant find speaker phone feature on my Motorola Razr V3 cell phone
Yes, This phone does have a speaker phone setting.
When in a call it should be the top right button on your keypad.
SOURCE: Bluetooth pairing on Motorola Razr V3
Razor V3m (Sprint) / Motorola H710 hands free. I believe my phones bluetooth is intermittent. I can get them to pair after about 15 minutes of trying, then once I open the ear piece it will not connect. The H710 will connect to other phone just fine.
Any ideas
