You might check out Ebay.
https://www.ebay.com/p/Tanaka-TBC-2510-trimmer-ignition-module-coil-1672052190/685434641
SOURCE: Need to find Tanaka tbc Grass Trimmer,carburettor service manual
Hello
If the Carburetor OEM is a Zama, then
>>You can View a Breakdown/IPL of the Carburetor and Get Technical Information on Zama Carburetors at this Site Addy; http://www.zamacarb.com/tips.html and Select the Technical Guide.
If the Carburetor OEM is Walbro, then
>>You can View a Breakdown/IPL of the Carburetor at this Site Addy, http://69.16.165.8/ and Select Service & Aftermarket. Now Select Aftermarket Parts and Service. Now Select the OEM (Tanaka). Now Select Trimmer. Now Select your Carburetor (?) from the List Provided.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
SOURCE: Oil water ratio tanaka TBC-2251
You must mean oil to gas ratio. I suggest following the instructions on the container. That is what I usually do. Best regards.
SOURCE: tanaka tbc 4500 manual
Visit the below link
http://www.tanaka-usa.com/pdf/dpl/trimmers_&_brushcutters/TBC-4500dpl.pdf
Please vote form me if the
