Hello, for what you describe your JVC, it requires a service of mechaning, replacement of belts and rubber pulleys, plus all the cleanings of old lubricants
If you have technical knowledge, I send you the link to download the service manual
If you are not looking for a specialized technical service
I hope you can listen again and rewind the tapes in your JVC
Greetings Franco Dosil
Hola, por lo que describes tu JVC, requiere de un service de mec?nica, reemplazo de correas y poleas de goma, mas todas las limpiezas de lubricantes viejos
Si tienes conocimientos t?cnicos, te env?o el link para que descargues el manual de servicio
Sino busca un servicio t?cnico especializado
Espero puedas volver a escuchar y rebobinar las cintas en tu JVC
Saludos Franco Dosil
https://www.electronica-pt.com/esquema/old-tv/jvc-kd-85-service-manual-48677
The tape could be bad. Try another tape.
No, I have same problem with all tapes.
SOURCE: Video will not rewind to beginning of tape.
the clutch gear needs to be replaced . you can order the part partstore.com go by brand and model easy to replace around 30.00 dls .
SOURCE: rewind
Dear Tim, In all likelihood the belts of your VCR have become old and worn. I suggest you unplug the machine, and open the bottom plate. You will now be able to see the Drive belts. Go to a Spare parts shop and buy a Belts set for your nodel from them, and replace. Also, try changing the REW/FF Idler unit. This should do the trick.
SOURCE: loud noise on rewind
You may have an idler gear wheel which has been damaged- perhaps broken/worn gear teeth or something afoul in it's drive mechanisms. Check this idler which sits down in between the supply and take-up spindles. You should be able to see this with no tape loaded. This idler should also move freely from supply to takeup- if it is sticky in movement this could be the problem. If your idler is broken, you may be able to replace it. Check with a service center- or a parts supplier. MCM electronics is one such supplier- there are others.
SOURCE: JVC KD-85 Cassette Deck Stops in Seconds in play, REW., & FF
Hineovision1
The deck will need new belts and idler drives cleaned and serviced, and perhaps some idler tyres replaced. You can get a belt kit from these guys. replacing them is not such a difficult job if you have some mechanical aptitude. Just take it slowly, and focus on getting the transport out of the unit.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
SOURCE: Player - rewind malfunction
I have a trv-58 with the same problem. One way is to press play and rewind while in play mode.Getting back to the first of the tape is a chore.
