Question about Watches
Is this watch water proof? - Watches
    Top Expert:
  • Watches Master
  • 30,954 Answers
How would we know this???
Posted on Apr 29, 2019
SOURCE:
Is my fossil watch watch water proof
Nope maybe water resistant for a few seconds only
Jan 24, 2016 | Fossil Watches
About three months ago, it was covered by water for about three hours and now will not power on. Tried reset button but no results.
you have to take the top of the watch and blow the water out. And then after you need to look on the bake of the watch and see if it says water proof or water resistence. can't spill just a little tired
Jul 17, 2015 | Watches
Are fossil 10 atm watches water proof?
No watch is "water proof." As a matter of fact, there's a U.S. law on the books that watches (and other equipment) can only be described as "water resistant," since nothing other than a solid object can completely shed water.
All that said, the 10 ATM designation is meant to convey that when the watch was new, it was supposed to withstand up to 10 atmospheres of external pressure--which would translate into being about 300-330 feet underwater. That's pretty water proof in my book.
HOWEVER, and this is a big caveat, a watch's water resistance rating is based on its condition at the time that it left the factory. Over time, the little gaskets that help keep water out of the watch will begin to wear and provide less water resistance. In particular, official factory servicing states that the neoprene gasket between the case and caseback of the watch should be replaced every time that you change the battery. In fact, most people, including me, re-use that gasket if it still looks pretty good when I open the watch. That definitely compromises the factory water resistance rating.
Bottom line: If you have a watch rated for 10 ATM of water resistance that's a few years old, I wouldn't be all that concerned about getting it casually wet, or even going swimming with the watch (I'm paranoid enough that I wouldn't do this, but I'm probably in the minority). However, I wouldn't go diving with a watch that's had its battery replaced unless it was re-tested for water resistance after the battery was serviced. Some but not all jewelers have special machines that perform this test. If you're interested, you could probably pay one of them a few dollars to have your watch tested. They don't have to do anything to the watch other than place it in their machine, so it's not a big deal for someone who has the equipment to perform this test.
May 20, 2011 | Watches
Is my bulova watch water proof?
If you look at your front dial you should see 30m, 60m, or 100m, if you see one of these numbers it is water proof, so for example 100 meters = 330 feet.
Apr 03, 2011 | Bulova Watches
How water proof can you dive to with them?
Only if the water resistance is 100m or more.
If your watch has a "no water" icon, then it should not be allow to get wet.
Sep 21, 2010 | Nixon Rotolog Leather Watch
Is this watch water proof? Could I go for a swim timing myself would the watch be ok or would it destroy the watch?
mcdevito75 here, If your Timex is a quartz watch then NO, water will destroy your watch. If your Timex is a windup, it must say waterproof and even if it does, every 2 years it is adviseable to see a watch repair shop for up dateing the waterproof status of any watch. I would advise not to use your Timex in any large amount of water.
Aug 17, 2010 | Timex Expedition 40141 Wristwatch
Oil all over wrist watch - can it be cleaned?
hi, if the watch is water proof witch most watches are, if it is it should tell you something on the back like wr 30m or wr 10m if it says this on the back then this is telling you that the watch is water proof up to 10metres or what ever it says if this is the case then you can put it in the sink with only slightly warm soapy water then just rub it over gently with soft cloth whilst under water.
How ever if it says water resistent then this dont mean its water proof this just means its rain proof but not made for going under water unless it says water resistent to 30m then this can be washed in the sink also if it dont say this then you cant put it in the sink you can only wipe over it with a damp cloth to remove as much oil as possible.
But if you can get it clean and its not water proof then the watch is going to have to be taken apart to clean the outer casing that is only if the oil has not got inside the watch.
Oil wont short the watch out put it can cause problems if you have any buttons on the watch so your best bet would be taking it into a watch shop and get it cleaned that way.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Watches
My Polar F6 is not water resistant like it's supposed to be??????
Your watch is water resistant...not water proof...which means if you get a little water on it, fine..but certainly not wearing it in the pool!
Jun 28, 2009 | Polar F6 Wrist Watch
Is my PUR60901W watch water resistance?
My knowledge, yes.  On the back of the watch should say something.
May 26, 2009 | Casio DW290 1V Classic Alarm Chronograph...
My problem is my Citzen Eco Drive works but the WR100 seems to be off. I under the theory of WR as opposed to water proof but, should it really be getting foggy under the crystal after i wash my hand? On a...
These water proof watches are only water proof if the knob for setting the time is pushed all the way in. Try to call your Citizen dealer, if you read them the numbers on the back yhey can see if there is warranty to check the problem for free.
If you need to know more about your Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Apr 06, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Watches Logo
56 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
