Health & Beauty Logo
A
Anonymous Posted on Apr 29, 2019
What are the tyre pressures for model shop rider TE- 888nr electric scooter, just been given one with no instructions
barrybam
Level 2:
Sergeant:
  • Expert 208 Answers
  • Posted on Apr 29, 2019
barrybam
Expert
Level 2:
Sergeant:
Answers
208
Questions
0
Helped
76755
Points
651
Possible the recommended pressure is printed somewhere on the tires themselves but will be the maximum. The recommended tyre pressures are Front 25 psi and Rear 30 psi. The tyre pressure must not exceed 50 psi (psi = pounds per square inch).
5 Related Answers
Anonymous
  • 490 Answers
  • Posted on Apr 21, 2009
SOURCE: tyre pressures
32 psi
Anonymous
  • 507 Answers
  • Posted on Oct 22, 2009
SOURCE: daihatsu charade 2005 model tyre pressure.
28 psi minimum but to stop the edges wearing prematurely,inflate to 34 psi and the tyres will wear better,as long as your happy with the ride...shouldnt be too firm
tombones
  • 3567 Answers
  • Posted on Apr 06, 2011
SOURCE: Peugeot scooter speedfight 100 tyre pressures
Look at the sidewall of both tires. There will be a 'MAX PSI' embossed on the tire. It will probably say Max 45 PSI. At 45psi the bike will ride like a rock. At 15psi it will ride really squirrely. Find a psi at which you feel the bike handles well and rides well. One rider may weigh 100 pounds and the next rider may weigh 300 pounds. The best psi for each rider will be different due to weight. Chances are that 30 to 35 psi will do the trick. Please rate my answer. Thanks.
Ironfist109
Iron
  • 3018 Answers
  • Posted on May 01, 2011
SOURCE: how to remove rear tyre from e300 electric razor
  1. With a Phillips screwdriver loosen the two screws and remove the chain guard.
  2. With a 10mm wrench loosen the brake cable anchor and disconnect the cable.
  3. With two 8mm wrenches loosen the brake housing anchor and disconnect. (Keep the spacer and washers together.)
  4. With a 10mm wrench loosen both axle adjusters an equal amount. (roughly five turns)
  5. With two 17mm wrenches loosen the axle.
  6. Push the wheel forward in the slots to loosen the chain.
  7. Pull the wheel out. (Pay careful attention to the order the hardware is in there.)
Regards, Tomy
Testimonial: " that tells me how to remove the weel but not the tyre but thank you anyhow "
Anonymous
  • Posted on Aug 27, 2011
SOURCE: pro rider scooter road king
The Problem was resolved by Pro Rider under warranty including 2 new front wheels. The scooter is now running better than ever!
1helpful
Tyre size for TE-889NR SF
tire sizes are moulded into the side of the existing tire
take the wheel to a tire shop or a mobility retailer if the tire shop cannot get one
My shop rider wheel chair is fully charged but won't but won't start
I HAVE A SHOP RIDER ELECTRIC SCOOTER.IF ITS THE SAME,
IS IT IN GEAR,ON MOST SCOOTERS THE LEVER IS UNDER THE REAR BUMPER AREA
Tyre pressure
You should find it marked on the wheel and or around a tyre valve. If you have standard tyres and tubes check your not very useful Pride instruction book.
1helpful
I want to know how to charge Shoprider TE 888nr
Hi. Plug your charger in after using it, and then leave it charging for 12 hours.
If you still have a problem, you will have to give me a bit more info. Good luck. Neil.
1helpful
Pro rider scooter road king new front tyres after 15 weeks ever since new tyres fitted violent shake on the front end
7helpful
I need a new battery for my Shoprider mobilty Scooter TE 888NR Can you please tell me which one I need, where I can buy it, and the price. Many thanks.
alison If you have a 4 wheel scooter midsize then you require 2 U1 batteries. If you have battery warehouse type store or an interstate battery dealer in your area you should be able to get them through them. At last resort you can go to the provider that sold you the scooter. Cost can be $175.00 to $225.00 for the pair. If you can or have help take the seat off the scooter remove the rear shroud or cover and you will see the batteries there look on the batteries and they should have a number on them like Universal UIB etc Hope this helps
Tyres and pressures
The Cali' Special tyre pressures:- --------------- 1 RIDER.---------------------- 2 RIDERS Front ...... 2.3 Bar(33.5psi) ................... 2.3Bar(33.5psi) Rear ....... 2.5Bar(36.3psi) .................... 2.9Bar(42psi) I use BT45's on mine but I have the ordinary tubed rims. I find the ride harsh but this may be down to suspension rather than tyres. People recommend running the BT45 at a slightly higher pressure than the book. I got 8500 miles from the front and 4700 from the rear. Although the rear was changed slightly early due to a puncture. I will probably try a different make next time.
Tyres and pressures
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
SmartAviator
SmartAviator
jws1013
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
