Hello Stephan, to reset the system of the Sylvania DVD player SDVD6655-B, you must unplug it for 30 minutes, after that time, reconnect it and test the operation
I enclose the user manual, on page 10 this information
Greetings Franco Dosil
Hola Stephan, para restablecer el sistema del Sylvania DVD player SDVD6655-B, debes desenchufarlo durante 30 minutos, luego de ese tiempo, vuelve a conectarlo y prueba el funcionamiento
Te adjunto el manual de usuario, en la pagina 10 esta la informacion
Saludos Franco Dosil
https://www.manualslib.com/manual/1066582/Sylvania-Sdvd6655-B.html
SOURCE: toshiba dvd setting
1. You would press and hold stop on the front of the unit for 5 seconds then let go and press it again normally, you can try this with both the power of the unit on and off.
SOURCE: need dvd code
Do you happen to know the model# of your Sylvania DVD/VCR player? That will help me access the correct codes for your set. Let me know, thanks!
SOURCE: DVD PLAYER
ok reset factory setting try to burn dvd if problem occer then u need to call a good technision
SOURCE: sumvision pheonix premiun dvd player
I'm guessing you have the player connected via HDMI.
You first need to connect via SCART and then through the menus, set output to HDMI.
SOURCE: can the sylvania video/mp3 player-smpk8854b be reset?
if you can navigate the screens you can, tap settings,default set, yes.
try reset on top of player if its acting up.
firmware is not available for these players.
