SOURCE: frigidaire dishwasher rinse cycle problem
problem just might be that not draining. when on drain, hold hose into a bucket about 3 feet off floor and check drain rate is good. if plumbed in under the sink, also check no blockage at the sink spigot
SOURCE: Frigidaire Gallery Series Dishwasher -
HI,
check your drain hose first for kinks or food blockage also check the
tail at the disposal or wherever you drain hose connects. Second there
may be a blockage in the pump itself take it off and check. If all of
this is ok I would suspect a pump that is going bad and replace the
pump..
Also check valve on the drain pump.
Goodluck,
Please don't forget to rate the solution.
SOURCE: dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
