Posted on Apr 29, 2019
I want battery for Coby MP3 player mp705-4g please update me if you have this on [email protected]
5 Related Answers
A
Anonymous
  • Posted on Apr 14, 2008
SOURCE: coby mpc7095 mp3 player
try resetting the device while plugged into your computer... also some of the pins might be bent inside de port of the player, make sure they are correctly set with a flat, small tool, what do you have to lose?
Anonymous
  • Posted on May 28, 2008
SOURCE: Coby installation
NECESITO EL PROGRAMA DE INSTALACION DE MI MP3 COBY
Anonymous
  • Posted on Oct 08, 2008
SOURCE: s1 mp3 player} player of 4GB decrease to 108MB
i have brought a new mp3/mp4{s1 mp3 player} player of 4GB.when ,i made a secert space with the help of mp3 disk tool.my memory of mp3/mp4{s1 mp3 player} player
is decrease.Now it show only 108 MB.
Anonymous
  • Posted on Nov 15, 2008
SOURCE: ''Freeware'' COBY software to download pic's, video and music
To upload file to the COBY MP3 player, I went to setting, went to USB setting's, changed MTP mode to MSC mode then I was able to get access to folders with-in the mp3 player.
The_Tonester
Anonymous
  • 46 Answers
  • Posted on Dec 20, 2008
SOURCE: ultra mp3 lisence key
dear customer thanks for contacting, nand ur serial to access ur ultra MP3 in ur nokia 6600 by just copy this code in your column 61560
I need the firmware for my coby 610-2gb mp3 player but the content website is no longer available so where can I get it
610 firmware update MP3 & Digital Media Players ... - Fixya
www.fixya.com > Forum > Tags > 610 firmware update
Ask your 610 firmware update mp3 and digital media player questions. ... ...610 2GB, purchased year and a half ago, so when i found the new firmware update ... I haveupgraded firmware of my t.soniv 610 with sigmatel MSCNMMC ... firmware of yourCoby 610 MP3 Player will unfreeze it and help it act normally again.
Coby mp610 firmware update - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesCoby mp610 mp3 player 2gb mp610 2g b h photo video. Firmware upgrades ... I lostmy cd for my coby mp610 4g so i can not syn fixya. Coby mp 610 4gb ...
Coby MP610-4G ' Owners Manual - ManualOwl.com
I have a coby mp-620 and it wont recognize it in coby media manager. No device found
you probablyhad a different coby mp3 player and its using an out dated version of Coby Media Manager, download the updated version from here: http://www.cobyusa.com/files/software/MP707_Media_Manager.zip
1helpful
Help with coby mp610/ac wont boot compleatly after format
After the format you might be missing files for operating the device.
Formatting the player is normally used before updating the firmware.
Have you been updating the firmware after you formatted the player ?
There is a new firmware release for the MP610.
Look in the support page, enter MP610 in the bar (Product Search) of next site:
http://www.cobyusa.com/?p=support
Download the zip file. Unzip the downloaded file with WinZip or WinRar.
Look in the pdf file for the instruction how to use the exe file for the
Firmware Update.
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
1helpful
COBY MP610-2G - FILE SYSTEM ERROR
you may have to get a firmware update
(download to computer, install utility, wire up player, run update..)
you will find firmware, specs sheet and manual for download here:
http://www.cobyusa.com/?p=doc
after doing the update, access player via win-explorer, erase all the mp3s(do not format!, as this will erase the firmware as well)
and drag and drop your new mp3/files onto the player.
unplug, press play and if everything is right: enjoy listening
Songs wont play :-(
You have to make sure your songs are MP3 or Unprotected Windows Media Audio files. You can check this by right clicking the song, go to Properties, it will tell you the type of file, make sure its says MP3 or the song is not compatible with the unit. Below is a link on how to add songs through windows media player:
http://http.vitalstreamcdn.com/cobyelectronics_vitalstream_com/setupguide/MPC7095_SG.pdf
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
