SOURCE: BLUE VERTICAL LINE
The address module that is at the bottom of the PDP in that location is the suspect and the cheapest repair. There is usually 3 to 4 modules at the bottom of the PDP and each one addresses information vertically. If it were just one pixe wide then the PDP would be bad.
SOURCE: red line on screen
you need a new video board on your tv i can sell you many boars you may know need i am also a full service man for tvs and electronics
573-433-1925
SOURCE: vizio 50 in.the plasma has a vertical blue line thru the light
make sure that the blue screen setting is turned off
SOURCE: 2 horizontal blue lines on samsung 50 plasma tv
Possibly could be the Y buffers --if the are next to each other could be a bad connection on a ribbon cable ---you need to call for service
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
