My Friends Pride legend xl 3 wheel scooter works fine in low speed and no codes, but if he turns up the speed to half way or more he can travel forward no problem but as soon as he reverses and lets go of lever, it keeps going and no brake activation. if he turns the key on in high speed, he gets 6 flashes and no operation.
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
SOURCE: My Pride Legend 3 wheel scooter will not go
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
SOURCE: The Pride GoGo 4 wheel scooter does not move
Hi. How many beeps between pauses? This is a fault code.
A couple of problems might cause this fault. Is your free-wheel lever in the correct place. These levers operate a switch, that tells the controller that the brake is disabled, this stops the controller from driving the scooter with out brakes.
Might also be caused by a stuck brush in the motor. This is usually caused by the caps that hold the brushes in, not being tight enough. Check the brushes, make sure they slide in and out smoothly, retighten the caps. Be carefull because these caps can crack easily.
Good luck. Neil.
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
SOURCE: Is it possible to get a copy of the repair manual for a 3 wheel Pride Legend XL scooter?
hi, it not a repair manual but a owners manual that is very helpful, the XL is my own personal favourite scooter but suffered from dodgy wiring and connectors otherwise it's a blast, I have reprogrammed the eGis controller to hit the max speed 10 mph.
Regards
GeWiz.
