Question about Onkyo Audio Players & Recorders
Onkyo CR-315 So i have this disc player bby Onkyo and the Cd tray wont open up anymore. When i Push the Open Button it says schon Open in the screen But it won‘t Open But you Heat the tray ob the inside working for a Short Moment.
  • 34 Answers
First of all, learn to use spellcheck.
Posted on Apr 28, 2019
2 Suggested Answers
SOURCE:
gopakumarg43
  • 76100 Answers
SOURCE: ONKYO CR-315 cd player locked.
Hello
Just try to reset the CD receiver by holding the clock call button and pressing the STANDBY/ON button.
Posted on Nov 30, 2011
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
Hello
Nov 30, 2011 | Onkyo CS5VL Super Audio CD Player Black...
I put 2 cd's on top of eachother. now the cd player wont open but it will turn on. when i turn it on it says mechanical error.
You could try gently sliding a thin blade in the top of the tray slot to hold the CDs down whilst, equally gently prising the underside of the tray with a small screwdriver (it may help to press teh open/eject button at the same time).
Feb 25, 2011 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
Ongkyo dv-sp302 dvd/cd player,disc tray open
Hi
I know the reply is a bit late but I had a similar problem.
The problem is with one IC close to where the motor wire are connected. This particular IC overheats and that was causing a malfuction. So I have installed a small heat sink and now all is well.
Hope this works for you too
All the best - Clayton
Sep 02, 2009 | Onkyo DV-SP302 DVD Player
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Harman kardon CDR 26 cd recorder
It's the belt from the spindle motor to the gear. It's worn and can't grip the spindle anymore. If you elp it to start off it works. Open the unit, remove the cd tray and it's underneath at the front. You can replace with a similar size elastic band.
Nov 14, 2007 | Harman Kardon CDR2 2-Disc CD Recorder
CD Carousel for the Onkyo Shelf System
Oct 11, 2007 | Audio Players & Recorders
41 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
