SOURCE: Low water pressure while the rest of the faucets
lume build up. pull handle out and unscrew there should be filter inside take out and soak in a cup of lime away overnite rinse well and reinstall
SOURCE: When turning on the shower faucet there is no hot water.
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Testimonial: "This information was extremely helpful especially when you know what to look for and have instruction."
SOURCE: low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
SOURCE: Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
SOURCE: New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
I had the same problem. I simply removed the small brass fitting that the water supply screws onto.i removed the screen that is inside the brass fitting. Now the pressure is fine.
