Question about Necchi Sewing Machines
My Necchi sewing machine. I can’t seem to adjust the stitch length
  • Necchi Master
  • 2,387 Answers
Doing a google search for the brand plus model number for a user guide or YouTube videos might find what you are looking for. That it is a Necchi doesn't supply the model number and of course models differ. On a 537L model, the large knob on the right side about halfway between the top and bottom of the machine adjusts stitch length. The numbers may range from 0 to 5 with 0 meaning no length and 5 being the largest length. Tension, stitch length and stitch width are all controlled by small dials on the front of the Necchi machine. If your stitch length is set to 0, the sewing machine will not feed the fabric. Incorrect tension will cause poor stitch quality. You must consult you machine's user manual to know how to adjust the tension as the procedure differs among machines. Here is a general guide, however:
How to Adjust the Tension on Sewing Machine
https://www.youtube.com/watch?v=i-7bnb_6EBU Necchi
Posted on Apr 28, 2019
SOURCE:
SOURCE: Necchi Stitch Length
When you press the level the machine goes in reverse. When you turn the dail to O it goes in reverse. The dail is somehow out of alinement and that is what I am searching for the adjustment that would bring the machine to O and the adjustment that would lengthen the stitch forward. When I push teh level for reverse it does go in reverse. I guess the question would be if you would like to lengthen the stitch further than the dail currectly allows how do you do that. THanks!
Posted on Dec 13, 2007
Mimito7
  • 130 Answers
SOURCE: Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
Posted on Apr 19, 2009
sew dutch
  • 25 Answers
SOURCE: I have a Necchi free arm mechanical sewing machine
I could not think of another way then free-motion sewing.
Drop the feed dogs, and put a spring loaded needle on.
Posted on Jun 29, 2009
SOURCE: I bought a vintage singer 201k, hand cranked. Sews like a dream, but the stitch length adjuster slips upwards to the smallest stitch length when sewing. The screws on the stitch length adjuster are
take the machine to a sewing machine shop & have them check the screw
or the stitch length adjuster, the threads could be stripped out
Posted on May 30, 2012
mizrach612
  • 102 Answers
SOURCE: Necchi 4825, cannot get machine to sew the different stitches - have tried adjusting width/length just all come out as some form of zig zag - arggh!
Since your machine is brand new, it is under warranty. Take it back to the dealer you purchased it from and have them repair it. If you try any repairs yourself, or by a 3rd party, that will probably void your warranty.
Posted on Sep 21, 2012
On necchi model 537L which buttons are for stitch length
It is generally the large knob on the right side about halfway between the top and bottom of the machine. The numbers should range from zero to 4 or 5. Zero is zero stitch length, five would be the largest stitch length.
https://docs.google.com/document/d/1OBOahdPrL29joIvK-_sddWvVcUuOblCc50xn2Q8eZrs/edit
http://www.sewingpartsonline.com/instruction-manual-necchi-537-l.aspx
http://www.sewingmachinemanual.net/Sewing_Machine_Manuals/Necchi/Necchi_537-L_instruction_manual.htm
Jan 09, 2017 | Necchi Sewing Machines
Adjusting the feed timming in relation to the needle on an alco/necchi model 130054 sewing machine .
Hello, 130054 isn't the right model number for the sewing machine. Can you get me more info? Can you supply the serial number too or any other numbers on the sewing machine?
Oct 27, 2015 | Sewing Machines
Sep 21, 2012 | Necchi Sewing Machines
HI THERE I HAVE BOUGHT A NECCHI 681C SEWING MACHINE SECOND HAND WITH NO INSTRUCTION MANUAL , I CANT GET THE MACHINE TO FEED THE FABRIC AS ITS SEWING IT JUST SEEMS TO SEW THE SAME ROW AGAIN AND AGAIN ??? I...
What is your stitch length set to? Is it possibly set to a low number? should be 2 or 3 for a normal stitch.
There is a website for the USA Necchi importer, http://allynint.com/index.html, Contact Information
necchilogo.gif contacts-no-e.gif Maybe they can help you obtain the manual for this machine.
Apr 13, 2011 | Sewing Machines
I'm having trouble gathering fabric...no matter how I adjust the stitch length it seems to be too tight and I break the threads when I try to gather. Help!
So you are sewing two rows of straight stitch at 10mm and 20mm from fabric edge with a stitch length of 4? Are you using good quality thread? I like Molynecke, Guttermann or Sylko Supreme.
Try loosening the top and bottom tension too, and use a gathering foot if you have one.
A quick solution is to zig-zag over a length of pearl cotton or similar heavy weight string/thread, this works well for large volumes of gathers such as around a bed valance frill.
For large volume gathering like cushions and bed frills, I use a pleater/ruffler attachment, however, this has only 3 settings so isn't a variable gathering effect.
Apr 04, 2011 | Necchi 3537 Mechanical Sewing Machine
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
Lost manual, don't know how to adjust the stitch length
HI,
Please provide us the model make and number so that we can assist you by sending correct manuals.
Jul 07, 2009 | Necchi 3620 Quilter Mechanical Sewing...
Dec 12, 2007 | Necchi 3102 Mechanical Sewing Machine
Sewing Machines Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
