SOURCE: 1996 es 300 lexus cd player wont play says error
For the cd player error.I just fixed mine i had to take the whole unit
out.Take it apart remove the laser and clean it .I'am a Electronics
Tech ( but it's not hard ) use a Q-tip and some 91% Isopropyl Alcohol.
This will help for new cd's.( before even new ones errored out)But old ones, it still error's out.
Because the laser is old and weak.But if you got the time it can't hurt.
good luck
SOURCE: my car battery died.when i put in a new my cd player stop working
If your radio is still working, then your power is OK. The Sony CD changer gets its power from the Sony Unilink cable. It is possible that it passed a power spike down to your CD player while hooking up your battery cables.
I just had a CDX-757MX just die a few days ago myself. My radio, amps, and other changers are still working. Could be an unfortunate coincidence.
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
SOURCE: We bought this clock for
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Usually that means it can't find the signal to sync itself.
