Question about Polaroid Televison & Video
Polaroid tv was connected to WiFi now it’s not and won’t even detect it when I try ..?
SOURCE:
  • 221 Answers
SOURCE: i cannot detect wifi connection even in wifi
You may have to go to your wireless connection properties then check to see if your laptop is set up to connect to any avaible network.
Posted on Mar 09, 2009
  • 22 Answers
SOURCE: Ds won't connect to wifi nintendo24 won't for the wii won't connect to the wifi
you need to get wifi at your house before you can use the wifi on the ds
Posted on Mar 24, 2013
  • 399 Answers
SOURCE: my seiki tv detects wifi but won't connect. even after i enter the password. how do i fix this?
One reason I can think of for your problem is this: your TV detects several other protected WiFi networks (probably from your neighbors) in addition to your own, and it is likely that you entered the password for your network when trying to connect to another network. To check if this is the case and if you don't know your network's name (actually this is called the network's SSID), do the following: turn off your modem/router, then check what WiFi networks are detected by your TV. Write down the names of those networks. Turn your modem/router back on and see what networks are now detected by your TV. The new one on the list is your WiFI network's SSID. Make sure that you connect your TV to that new network.
Posted on Dec 26, 2014
Testimonial: "Thank you. Did not think of that. I had to switch my router from WEP to WAP and change my password to a shorter one."
  • 250 Answers
SOURCE: My just purchased Luxor 42" smart TV keeps flashing up "wifi dongle romoved" "wifi dongle detected" when trying to connect to the Internet. It's suppose to have built-in wifi. Can someone please help.
Take it back to the store you bought it from, and ask them to fix it or replace it for you.
Posted on May 02, 2015
SOURCE:
Could be a corrupt Wi-Fi receiver module, before you rip it apart if it’s not under warranty.
Buy an external USB Wi-Fi adapter and insert it into the TV see if that resolves the issue.
Unless your an electronic geek or you have the electrical diagram you really won’t know what the WiFi unit looks like or if it’s even a detachable board. It maybe built into the entire circuit.
Posted on Dec 14, 2017
Have a Vizio E601i-A3 tv. It is not detecting any wireless networks all of a sudden. Was connected and watching Netflix, then nothing. Have reset the modem and other things are connected, but tv...
Dec 14, 2017 | Vizio Computers & Internet
I have a 50inch smart polaroid tv that wont connect to my wi fi what can i do
Have you connected any other new device to Wifi ? This is verify if you remember the Wifi SSID password.
Aug 01, 2016 | Polaroid Televison & Video
My seiki tv detects wifi but won't connect. even after i enter the password. how do i fix this?
Dec 26, 2014 | Computers & Internet
How do I connect to my wifi
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
Cheers
Nov 17, 2014 | Polaroid 7" Internet Tablet Android 4.0...
How do I get my tablet to connect to a network, no matter where i go it says there is no connection even at the library, when i am physically inside
You likely have a setting to turn on WiFi. This option is to save your battery, as WiFi drains your battery if it is on continuously. If it is turned off, you will never receive a WiFi signal.
Nov 05, 2014 | Polaroid 7-in. Internet Tablet - Other
The Netflix screen tells me I am not connected to the internet. What can I do to get reconnected.?
Go to your TV settings.... see if the TV detects the wifi signal.... if not try entering you wifi password to connect.
THE TV NEEDS TO DETECT THE SIGNAL FIRST. If not, try raising your modem to a window sill or a shelf, it may not be getting the signal. If it is getting the signal, call Netflix 800.585.7265....and explain your problem.
Good luck.
Oct 20, 2014 | My Local TV iPhone Apps
Wifi headphones
assuming that it is a wireless head set, will you need to plug in the usb dongle into the television. there might also be a sync button on both the dongle and headset that you will need to press, first on the dongle then the headset.
Jan 21, 2014 | Polaroid Televison & Video
My samsung smart tv won't connect to my network
You need to setup all you computer network to home network not public network because in order to connect you need to have a password which you need for every system in your home. Consider which computer is your main system. Then go to control panel and select networking icon and select network status. Now click on where it says Public Network or even Home Network and re choose home network and right down the code password. Then click ok and you are set. Go to your TV and choose to setup network, then choose to detect network automatically and choose your network. Then type in your password and you are set. Try it now and you should be able to view your photos, videos and so on. Good luck and let me know you you go!!
Sep 29, 2012 | Samsung 46" Full Hd Led Lcd Slim 1080p...
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
