Question about HP LaserJet 3050 All-In-One Printer
&lt;span <span onmouseover="_tipon(this)" onmouseout="_tipoff()"><span class="google-src-text" style="direction: ltr; text-align: left">Describe your &usg=ALkJrhiIfIvruNfH8EJDwYmvlU9vSu...</span> Describa su SGA = ALkJrhiIfIvruNfH8EJDwYmvlU9vSu y ...</span> <span onmouseover="_tipon(this)" onmouseout="_tipoff()"><span class="google-src-text" style="direction: ltr; text-align: left">Problem</span> Problema</span> trato de mandar un fax de la hp laser jet 3050 y me manda un mensaje de no hay respuesta como lo soluciono ???
2 Suggested Answers
SOURCE:
rajdeepdutta
  • 2517 Answers
SOURCE: cuando instale a 5to usuario
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
I need a code of a simple login form with the output
<?php
require("db/config.php");
session_start();
if(isset($_POST["btnLogin"]))
$nm=$_POST["txtUid"];
$pas=$_POST["txtPass"];
$q=mysql_query("select * from userinformationtb where user_id='$nm' and password='$pas'");
$data=mysql_fetch_array($q);
$_SESSION["seid"]=$data["user_id"];
// session_id();
if($nm==$_SESSION["seid"])
header("location:php/home.php");
//echo "valid";
else
echo "invalid";
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Untitled Document</title>
<link href="../css/style.css" rel="stylesheet" type="text/css" />
type="text/javascript" src="js/script.js">
type="text/javascript" src="js/cufon-yui.js">
type="text/javascript" src="js/arial.js">
type="text/javascript" src="js/cuf_run.js">
<link rel="stylesheet" href="css/validationEngine.jquery.css" type="text/css"/>
src="js/jquery-1.8.2.min.js" type="text/javascript">
src="js/jquery.validationEngine-en.js" type="text/javascript" charset="utf-8">
src="js/jquery.validationEngine.js" type="text/javascript" charset="utf-8">
jQuery(document).ready(function(){
// binds form submission and fields to the validation engine
jQuery("#frmLogin").validationEngine();
</head>
<body>
<form id="frmLogin" name="frmLogin" method="post" action="">
<table width="548" border="0" id="txtbrder">
<tr>
<td width="90" height="">Enter User Id </td>
<td width="152"><label>
<input name="txtUid" type="text" id="txtUid" class="tnm validate[required,custom[email]] text-input" />
</label></td>
<td width="56"><div align="left">Password</div></td>
<td width="154"><label>
<input name="txtPass" type="password" id="txtPass" class=" tnm validate[required] text-input validate[required,minSize[6]] text-input" />
</label></td>
<td width="74"><label>
<input name="btnLogin" type="submit" id="btnLogin" value="LogIn" style="background:#0000FF;color:#fff;"/>
</label></td>
</tr>
</table>
<a href="php/userinfo.php">Create New Account</a> &nbsp;&nbsp;&nbsp;&nbsp;
<a href="php/forgotpassword.php"> Forgot Password ?</a>
</form>
</div>
</body>
</html>
Oct 31, 2013 | Computers & Internet
Tip
Untethered Jailbreak for iPhone 4.3.3 OS
It%20is%20now%20possible%20to%20untethered%20jailbreak%20iPhone%20ios%204.3.3%20with%20RedSn0w%200.9.6%20rc16%20here%3A%20https%3A%2F%2Fsites.google.com%2Fa%2Fiphone-dev.com%2Ffiles%2Fhome%2Fredsn0w_win_0.9.6rc16.zip%3Fattredirects%3D0%26amp%3Bd%3D1%3Cdiv%3EJust%20update%20your%20iPhone%20to%204.3.3%20and%20use%20the%20file%20you%20have%20downloaded%3A%20iPhone3%2C1_4.3.3_8J2_Restore%20and%20use%20it%20with%20the%20RedSn0w.%3C%2Fdiv%3E%3Cdiv%3EWas%20tested%20and%20works%20great%3Cspan%20class%3D%22Apple-style-span%22%20style%3D%22color%3A%20rgb(102%2C%20102%2C%20102)%3B%20font-family%3A%20Arial%2C%20Tahoma%2C%20'Century%20gothic'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20line-height%3A%2024px%3B%20%22%3E%20%3C%2Fspan%3E%3C%2Fdiv%3E
on May 09, 2011 | Apple iPhone4 4G iPhone 4
Why other leter n ke board not function
its just dirty contacts if you can open your keyboard, clean contacts with non rubber eraser like the ones used by engineers and draftsmen. also include the rubber contacts under the keys
Jul 25, 2012 | Acer Computers & Internet
&amp;lt;span
Lo siento si mi español es malo - Yo uso un traductor. Contacto Dito Dean y debe ser capaz de conseguir un manual. Número de teléfono Dito Dean debe estar en la propia máquina. Por lo general, será sellado en la parte posterior o inferior. Buena suerte! :)
Aug 27, 2009 | Dito Dean Food Prep BKP-350 Bermixer...
My door locks do not operate when using remote on key fob
If it's the remote buttons wearing out (check by taking remote apart and bridging the contacts with a small screwdriver. If it works fine that way, go to keylessfix.com $10.00 will fix it.
/******************************************************** This Script will be included in all web pages to show an Icon on Mouse over, Clicking the Icon will show a Zoominto Viewer (a Flash made viewer) to Zoom the Image Content ********************************************************/ var tmppluginServername = "http://www.zoominto.com/zoomapi/"; //tmppluginServername= "http://localhost:9999/zoomapi/" var versionswf="1100"; versionswf=""; var tmppluginSwfname="" tmppluginSwfname=tmppluginServername + "zoomplugin" + versionswf + ".swf"; var tmppluginimageURL=tmppluginServername + "displayimage.php?image="; var protocol = "http://"; var isInternetExplorer = navigator.appName.indexOf("Microsoft") != -1; plugin_run(); function BrowserZoomPlugin() { var ua, s, i; this.isIE = false; this.isNS = false; this.version = null; ua = navigator.userAgent; s = "MSIE"; if ((i = ua.indexOf(s)) >= 0) { this.isIE = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Netscape6/"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Gecko"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = 6.1; return; } } var browser = new BrowserZoomPlugin; var dragObj = new Object; dragObj.zIndex = 0; function zoominto_dragStart(event, id) { var el; var x, y; if (id) { dragObj.elNode = document.getElementById(id); } else { if (browser.isIE) { dragObj.elNode = window.event.srcElement; } if (browser.isNS) { dragObj.elNode = event.target; } if (dragObj.elNode.nodeType == 3) { dragObj.elNode = dragObj.elNode.parentNode; } } if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.cursorStartX = x; dragObj.cursorStartY = y; dragObj.elStartLeft = parseInt(dragObj.elNode.style.left, 10); dragObj.elStartTop = parseInt(dragObj.elNode.style.top, 10); if (isNaN(dragObj.elStartLeft)) { dragObj.elStartLeft = 0; } if (isNaN(dragObj.elStartTop)) { dragObj.elStartTop = 0; } dragObj.elNode.style.zIndex = ++dragObj.zIndex; if (browser.isIE) { document.attachEvent("onmousemove", zoominto_dragGo); document.attachEvent("onmouseup", zoominto_dragStop); window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { document.addEventListener("mousemove", zoominto_dragGo, true); document.addEventListener("mouseup", zoominto_dragStop, true); event.preventDefault(); } } function zoominto_dragGo(event) { var x, y; if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.elNode.style.left = dragObj.elStartLeft + x - dragObj.cursorStartX + "px"; dragObj.elNode.style.top = dragObj.elStartTop + y - dragObj.cursorStartY + "px"; if (browser.isIE) { window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { event.preventDefault(); } } function zoominto_dragStop(event) { if (browser.isIE) { document.detachEvent("onmousemove", zoominto_dragGo); document.detachEvent("onmouseup", zoominto_dragStop); } if (browser.isNS) { document.removeEventListener("mousemove", zoominto_dragGo, true); document.removeEventListener("mouseup", zoominto_dragStop, true); } } function imgplayerprogress_DoFSCommand(command, args) { var imgplayerprogressObj = isInternetExplorer ? document.all.imgplayerprogress : document.imgplayerprogress; } function zoominto_addElement(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.setAttribute("title", ""); newdiv.style.position = "absolute"; newdiv.style.display = "none"; newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { } } function zoominto_addmyelems(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { //_L(e); } } function zoominto_initializelements() { zoominto_addElement("plugpanel", " "); zoominto_addmyelems("plugincheck_0909", ""); } function zoominto_GetElementPostion(theElement) { var selectedPosX = 0; var selectedPosY = 0; tmpw = theElement.width; tmph = theElement.height; while (theElement != null) { selectedPosX += theElement.offsetLeft; selectedPosY += theElement.offsetTop; theElement = theElement.offsetParent; } var tempelement = new Array(selectedPosX, selectedPosY, tmpw, tmph); return tempelement; } function plugin_showdeadcenterdiv(Xwidth, Yheight, divid) { var scrolledX, scrolledY; if (self.pageYOffset) { scrolledX = self.pageXOffset; scrolledY = self.pageYOffset; } else if (document.documentElement && document.documentElement.scrollTop) { scrolledX = document.documentElement.scrollLeft; scrolledY = document.documentElement.scrollTop; } else if (document.body) { scrolledX = document.body.scrollLeft; scrolledY = document.body.scrollTop; } var centerX, centerY; if (self.innerHeight) { centerX = self.innerWidth; centerY = self.innerHeight; } else if (document.documentElement && document.documentElement.clientHeight) { centerX = document.documentElement.clientWidth; centerY = document.documentElement.clientHeight; } else if (document.body) { centerX = document.body.clientWidth; centerY = document.body.clientHeight; } var leftOffset = scrolledX + (centerX - Xwidth) / 2; var topOffset = scrolledY + (centerY - Yheight) / 2; var o = document.getElementById(divid); var r = o.style; r.position = "absolute"; r.top = topOffset + "px"; r.left = leftOffset + "px"; r.display = "block"; } function pluginalertShow(layerid) { document.getElementById(layerid).style.visibility = "visible"; document.getElementById(layerid).style.display = "block"; plugin_showdeadcenterdiv(280, 115, layerid); document.getElementById("plugin_btn_activate").focus(); } function pluginalerthide(layerid) { document.getElementById(layerid).style.visibility = "hidden"; document.getElementById(layerid).style.display = "none"; } function zoom_getValidString(){ return "&isValidviewer=1";// all things are valid } function zoominto_showflash(zoomres) { try{ if(zoomres == undefined) zoomres="600x442"; zoomarr=zoomres.split("x",2) var divimgplayer = document.getElementById("div_plugin_img_player"); divimgplayer.style.display = "block"; divimgplayer.style.visibility = "visible"; //old movie 550 400 // plugin_showdeadcenterdiv(600, 371, "div_plugin_img_player"); plugin_showdeadcenterdiv(parseInt(zoomarr[0]), parseInt(zoomarr[1])+120, "div_plugin_img_player"); // zoominto_setImage(); zoominto_changeobject(document.getElementById("plugpanel").title,zoomres); } catch (e) { } } function zoominto_closeflash() { var divimgplayer = document.getElementById("div_plugin_img_player"); divimgplayer.style.display = "none"; divimgplayer.style.visibility = "hidden"; } function hidezoomicon(){ document.getElementById("plugpanel").style.visibility = "hidden"; } function getMouseX( e ) { return e.pageX '' ( e.clientX + ( document.documentElement.scrollLeft '' document.body.scrollLeft ) ); } function getMouseY( e ) { return e.pageY '' ( e.clientY + ( document.documentElement.scrollTop '' document.body.scrollTop ) ); } function dhtmlLoadScript(url) { var e = document.createElement("script"); e.src = url; e.type="text/javascript"; // document.getElementByTagName("head")[0].appendChild(e); document.getElementById("addiv").appendChild(e); } function getactualimgdimensions(imgsrc){ zoomintoheavyImage = new Image(); zoomintoheavyImage.src = imgsrc var tempelement = new Array(zoomintoheavyImage.width, zoomintoheavyImage.height); return tempelement; } function plugin_run() { var newcss = "#div_plugin_img_player td {padding:0;} \n #div_plugin_img_player th {padding:0;}"; if ('\v'=='v') /* ie only */ { document.createStyleSheet().cssText = newcss; } else { var tag = document.createElement('style'); tag.type = 'text/css'; document.getElementsByTagName('head')[0].appendChild(tag); tag[ (typeof document.body.style.WebkitAppearance=='string') /* webkit only */ ? 'innerText' : 'innerHTML'] = newcss; } var image = document.getElementsByTagName("img"); var totimgLength=image.length; zoominto_initializelements(); for (var i = 0; i 50 && zoomarrdim[1] > 60) { image[i].onmouseover = function () {imgvals = zoominto_GetElementPostion(this); document.getElementById("plugpanel").style.display = "block";document.getElementById("plugpanel").style.visibility = "visible";document.getElementById("plugpanel").style.left = imgvals[0] + "px";document.getElementById("plugpanel").style.top = imgvals[1] + "px";document.getElementById("plugpanel").title = this.src;}; image[i].onmouseout = function (evt) { imgvals = zoominto_GetElementPostion(this); strx=imgvals[0]; stry=imgvals[1]; endx=imgvals[0] +imgvals[2] ; endy=imgvals[1] + imgvals[3]; tmpcurx=evt.pageX; tmpcury=evt.pageY; if(tmpcurx > strx && tmpcurx stry && tmpcury 1 && match[1] != "") { output += match[1]; x += match[1].length; } else { if (clearString[x] == " ") { output += "+"; } else { var charCode = clearString.charCodeAt(x); var hexVal = charCode.toString(16); output += "%" + (hexVal.length Default115%125% \n"; document.getElementById('resselect').value=zoomres; }
Mar 26, 2009 | 2008 Buick Lacrosse
HP LaserJet 3050 All-In-One Printer Logo
135 people viewed this question
Clive
Clive
Thomas F. Schneider
