SOURCE: Sony LCD (Model no. KLV-26V300A), standby light
Good day.
Blinks in the indicator signifies malfunction particularly in the
horizontal and vertical sections. It is sometimes caused by loose
connections due to wear and tear.
If parts would be available, then there would be no such thing as
obsolete boards. You can request your technician to have the degree of
repair be evaluated first to determine if the expenses would justify
its existence.
Your respose is highly appreciated.
Regards,
Arjun
SOURCE: Sony KLV-S32A10 32 when i turn on picture come then goes off
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
SOURCE: I have sony Bravia KLV
AKB circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on the
A board. In addition, unit could be in IK blanking, try turning up
screen slightly.
SOURCE: Sony LCD TV Model #KLV-23HR2 The timer LED
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
SOURCE: my sony lcd tv model kdl40ex400 red light blinks
My TV did the same thing. According to Sony the Bulb or lighting mechanism is bad when 6 red lights blink and your TV fails to turn itself on properly.
If you have a warranty they'll likely replace the television set as they said "it isn't cost efficient to fix this issue."
