SOURCE: Xerox 4150 Workcentre, when xeroxing
Sorry I didnt see your post a while back.
You shold call and have the firmware updated on that machine.
There are several firmware updates to the 4150 that resolve a lot of problems with the machine/.
SOURCE: Xerox 4150 not scanning to network
I need more information, like is it scanning using the SMB protocol or FTP. Are you using active directory, etc. Usually, when they just quit, it is due to a Microsoft security patch, or a software firewall having been enabled. If you're sure that it is neither of the above, try browsing to the Xerox via the IP address, go to the properties tab, services, network scanning, file repository set-up, and see if the login name used for network scanning is qualified: (i.e. - domain\username) Often, in a business environment, that will help.
SOURCE: Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
SOURCE: Xerox 4150 continues to jam on first print - "print engine jam"
Chances are you have a buildup of toner on the charge corotron. This is a part of the copier that charges the drum to accept toner. If there's buildup of toner inside or on the grid of the corotron then the charge will be erratic or excessive and cause the paper to jam as it passes by the drum.
Check your user manual on how to properly remove and clean/replace the corotron.
SOURCE: I have a xerox workcentre 4150. how do I get it
Without looking at the machine, it sounds like the covers is set to "On" in the paper features selection. If you can get into the menu, find the tray, select paper, select white paper, not covers or transparacies.
