Question about Xerox Office Equipment & Supplies
What can i do when my xerox 4150 fuser module low?
  • Samora Cliford
    Samora Cliford Jul 24, 2019
    actual you can reset the thermostat of the fuser.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
Replace it
Posted on Apr 28, 2019
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 208 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
Try this before replacing the fuser.
You do have to reset a new fuser also.
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset.
Posted on Dec 03, 2007
StevenC82
Steven C
  • 160 Answers
SOURCE: xerox work centre 4150 screen states faulty fuser
That is in fact a bad fuser which must be replaced (part# 126N00321 for 110v). Replacing it is simple, open the right door and remove the 4 screws that hold in the fuser. Make sure the machine has been off for awhile because the fuser my be hot. Here is a video that shows you how. Hope it helps, and thanks for using fixya
Posted on Jul 12, 2011
Steven Taylor
  • 6 Answers
SOURCE: xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until af
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
Posted on May 02, 2013
Xerox Fuser will not warm up? Any idea why?
The fuser is nothing more than a heater element. One fuser is broken and the other isn't. You need a new one.
Or did you mean the broken one works in the other machine? In which case the power to it is disconnected somewhere.
Dec 27, 2015 | Xerox WorkCentre 4150 Black and White...
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox work centre 4150 screen states faulty fuser module. Can't seem to find part...Help
Dec 20, 2010 | Xerox WorkCenter 4150 Black and White...
I need to know what the part number is for the maintenance kit for work centre 4150
Here is a link to all the available parts and supplies for the Xerox 4150. This includes part number, yields and even pictures.
http://www.precisionroller.com/search.php?q=xerox+4150
Good Luck and Thank You for using Fixya.
Oct 12, 2010 | Xerox WorkCentre 4150 Black and White...
Do you have any instructions on how to clean a Xerox Workcentre 4150. It is leaving a dark streak down the right hand side of the page on everything it prints, not just copies.
First the to do is a "stop test." You will induce a jam before the paper reaches the fuser (which the the hot thing near the exit). The PN for the fuser is 002N02557.
If the defect exists already then the drum or transfer roller or laser may be causing it.
There are very few things that you could clean except the glass on top or the pick rollers.
Whit
Item, Inc.
Aug 23, 2010 | Xerox WorkCentre 4150 Black and White...
Open Questions:
37 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
