SOURCE: 150CC Roketa Scooter
Hi and welcome to FixYa,
On most versions of Roketa 150cc engines, the choke is automatic and electrically driven.. It is integrated with the carburetor.
Good luck and thank you for asking FixYa.
SOURCE: what can make a 50 cc roketa scooter not get any
If it just die on you changes are;
Faulty spark plug.
Blown fuse.
CDI box is shot, Knock offs are about 25 to 30 bucks
Hope this helps you out.
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
SOURCE: Battery good, regulator good, stator good, battery won't charge
you have caused a wireing fult thats all, it likely to be a bad earth on the bars or you may have blown a fuse by shorting some thing out when you were doing the work start checking the wireing out with a meeter start from the regulator you should have volts from there back to the battery check for a main fuse as well
SOURCE: AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
