Question about Viper Vehicle Parts & Accessories
Specter Viper Error 87 Fix?
Volume stuck is the error. Wondering if there is an easy fix.
SOURCE:
tom19511
  • 1601 Answers
SOURCE: Fatal error
That is a control board error.
i dont think that it would be hard to change out.
but the board price may deter you from fixing it. Considering it about 5 or 6 years old.
here is a list of parts for your printer. I cant find prices for it . you can call Okidata for it.
http://belgium.oki.com/binaryData/20824/c515300_rsplddr1.pdf
Posted on Nov 04, 2007
SOURCE: Error 1935
I have the same error. I've called their help support line, and they did not offer a solution. One operator told me they did not have a fix for this error, and they would contact me within 24 hours to give me the resolution. They did not contact me. I called back and spoke to a second help support operator, and I was told by them there must be a problem with my system. Looks like the software is broken for some Vista OS's.
Posted on Feb 24, 2008
SOURCE: Error message 50
Confirm Success on a 440CN
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees
2) make a note of where each connector goes
3) release the Ribbon and 3 Multicore cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees.
4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.
5) Remove front panel by disconnecting ribbon and wireing on both sides.
6) Remove 6 Screws (2 on back, three at front and one middle right
7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.
8) Re-Seat Encoder Strip into guide. (The Transparent strip)
9) Re-assemble in reverse and Hey Presto.
All Cured. Hopefully!
Posted on Aug 04, 2008
  • 126 Answers
SOURCE: Error Code F1-87 Finisher Trouble on Sharp AR-M350U+
It is a stapler rotation error. The stapling tray pressure arms become dull at the tips, so when the stapler attempts to move into position to make the staple it cannot move the guides out of the way.
First choice) Replace the (4) stapling tray pressure arms (LSTPP0357FCZZ). After you replace them you'll see that the tips get worn down, and wedge into place so that the black support plates cannot move out of the way of the stapler. The black plates look warped, but they aren't (I should say they always look like that).
They are fairly easy to get to. You do have to remove the finisher from the copier. Remove the front and rear covers. Open the right door. Pull the pins that retain the door. From there you'll see the arms. They can be changed with a little maneuvering.
2nd Choice) Clip overtight wire ties to the stapler rotation home position sensor.
3rd Choice) Shake down the stapler to its bottommost position (wherever it settles is fine). Adjust the flag that triggers the stapler home position sensor. If I remember correctly its the narrow **** in the flag.
Posted on Jan 28, 2009
  • 51 Answers
SOURCE: lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
Posted on May 15, 2009
How do I Fix iPhone Error Code 1015?
iTunes error 1015 is always along with the "plug into iTunes" screen stuck on iPhone. Indeed, that is the common error "iPhone stuck on recovery mode". Easy and quick way to fix it is to use the Re Boot. ... The error is that iTunes recognises a corrupt version of it's ios and will not complete signing.
Mar 16, 2018 | Cell Phones
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Error Code B1275 13
Fix the water leak first. Got a sun roof? Water in the BCM will cause all sorts of funny things, to included not letting you car start and run. Fix that leak first( Like today or tomorrow), then find your BCM(body control module) , pull it out and remove the cover around it. Wipe it off with a cloth, use a blow dryer and dry it up use the dryer to dry out the plugs also, then wipe it off again with another cloth. You let moisture set in it too long, it could kill it...
Apr 16, 2014 | 2010 Honda Accord
Viper 5701 not remote starting or unlocking
It's possible that you may have inadvertently locked the remote. Press "F" then unlock to unlock the remote. Then attempt to send your command.
Oct 15, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have the viper 5701 on a bmw 540i and the alarm works so does the keyless but the remote start does not work, the park lights flash 7 times and gives an error code,what can cause this?
The flashing parking lights signal a shutdown diagnostic. There is a nuetral safety switch under the dash. It's a toggle switch that needs to be in the on position. Also, the hood pin needs to be making contact with the hood when the hood is closed.
Jun 28, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 5701 transponder gives error code of five blinks even though it does the function
Five blinks of the parking lights during remote starter operation is an error code for the (+) brake shutdown. If your foot is not on the brake then, there is an issue with your brake switch or your parking lights and brake lights wires are making contact, possibly in one of the front or rear light housings. Corrosion maybe.
Mar 15, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When the camera is turned on a FOCUS ERROR shows up on the screen and will not disappear. Also the zoom lens is stuck half way out. Is there an easy fix. Regards LORRENZO.
I don't think there is an 'easy' fix for this except to send it in for professional service as the gears are not meshing right inside the camera causing this focus error.
Feb 04, 2011 | Cameras
Hi, when I try to use my starter option on my viper 5701 I get an error tone. when i turn off the ignition or try to use the starter option I get seven flashes on the parking lights. what does it mean and...
Seven flashes is the neutral safety switch. Check under the dash for the toggle switch labeled "on/off" and flip the switch to on. If this unit was just installed and you have always received the error tone then, the thin black/white wire must be connected to ground.
Jan 11, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The system detected a disk volume error which is indicated avery time I boot the notebook. And the system indicates that it can not open some files to do the automatic repair. In additon indicates that...
HI, here are the easy steps in doing the check disk on your computer to fix the error:
  1. Click on the pearl
  2. Click on Computer
  3. Right-Click on Local disk c:
  4. click on the tools tab
  5. click on the button for check disk
  6. it will ask you an option to fix disk error during the scan
  7. the it will ask you to reboot the computer after clicking on start
  8. when you restart your computer check disk will run before going to the desktop
  9. it should detect for any errors and fix it for you.
Cheers!!
Sep 01, 2010 | Computers & Internet
Vehicle Parts & Accessories Logo
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
garyg7133
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
