SOURCE: It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
SOURCE: Cd tray wont close, cds wont play
Sounds like you probably have a stretched belt on the load motor. Unplug the unit and remove the case which will expose the load motor. Plug in and turn on and press tray in button. You should hear the motor run and if you can see the belt you should see it slipping. Some belts are easy to change, and some are next to impossible. If you have to disassemble anything be sure that you note the position of everything as the timing of the tray, door, laser and most items in the unit is very critical. Let me know if you need more help.
hardrocko
Thanks for using FixYa
SOURCE: cassette door will not open
below the push button their is a tiny whole , take a needle of about 3---4 inches in length and insert in that whole and your door will slightly comes out then open it with your fingers
SOURCE: cassette player doesnt play or record, ff or
Hi.
If you hear a faint whirring sound from the cassette player while performing these functions, the motor is fine, but you require a new drive belt/s that need to be fitted at an electronics shop. If you hear not sound at all, the motor has died (possibly belts too), again it will require and electrinics repair shop visit.
For the sake of repairing it, it maybe cheaper to buy a new one.
SOURCE: 2002 Hyundai Sante Fe 2.7 cd/cassette/am/fm
Internal electronics failure. Whenever this issue rears its ugly head, we replaced the entire unit as no repair facilities are available.
