SOURCE: DSC-F717 - "stucked" in nightshot mode
Yes you are right, it is more than likely the nightshot button that has shorted.
This is button is part of what we call the Switch control Block.
Phone your local Sony service Centre and ask them how much it would cost to replace the switch control block. My estimate is about a 1/5 of the original cast you paid for the camera.
Good luck.
On my PDV-288 EVERY button has to be pushed down FIRMLY and for several seconds....My sound is also very low...
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
SOURCE: printer dell 1710n will not
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
Troubleshooting starts on page 60
Pretty much, all the basic steps, remove toner cartridge, ensure the paper path is clear, re-seat the toner cartridge, make sure all doors are fully closed then power on.
If no change time to call tech support.
SOURCE: Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
