SOURCE: Dishwasher doesn't wash with hot water
just about ALL dishwashers only fill up with cold water (one pipe) the machine warms the water up etc, simple one to solve, just connect up so and use it, one cold water in, one waste pipe out
SOURCE: candy aquaviva 1000 es
Are you sure that this not is the cooldown phase of the mainwash? Most frontloaders have this feature.
SOURCE: Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
SOURCE: Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
