Televison & Video Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Phillips PC7225 C121 ..I programmed it to a universal remote and went to menue.. it says Barker, Channel, Firmware ..I put it on channel but cant get to do anything after that...what do I do... I need to add channel 66 to this tv and it only goes to channel 60.
Anonymous
Level 2:
  • Expert 60 Answers
  • Posted on Aug 07, 2009
Anonymous
Expert
Level 2:
Answers
60
Questions
0
Helped
14774
Points
124
I need to add channel 66 to this tv and it only goes to channel 60.- the remote or the tv.?.
if remote doit mannuly on the tv.
if tv. .............................
1helpful
Sanyo and tv remote problems
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philips
If you know the model of your Phillips remote, you should be able to fihd it here, download the file, then unzip user guide. Hope this helps.
1helpful
I have a phillips universal remote and I need the code that matches to a Liteon dvd player and recorder. Model LVW-1101HC1
The codes that I have are for the LVW-1101 ( and possibly 1105). The remote responds to the JVC remote code [0623] but the individual command buttons are scrambled and need to be programmed in-unless you have the remote w/ learning):
266-play 286-TV (as source)
292-Fast Rewind 296-Cursor Rt.
301-Fast Forward 304-Record
316-1 325-7
326-Cursor/Channel Up 328-Timer
329-0 330-Menu
364-Setup 365-Select
367-Stop 368-Previous Track
369-Cursor/Channel Down 385 Commercial Skip
389-Source 390-Next Track
413-Cursor Left 416-Display
417-2 420-Open/Close
421-3 427-4
431-Top Menu 433-Navigate Menu
452-5 453-Easy Guider
454-9 455-Power
459-6 462-Tools
474-8 479-Pause/Step
500-Channel Editor
Finding the codes is not hard-just tedious.
7helpful
4answers
Philips PC7225 hotel TV - can't access the menu to reprogram it.
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
2helpful
I have a philips pm335 universal remote control
I went to the Phillips website and I wasn't able to find a code list. However, I did find the instructions to program your remote with "code search". Basically, it might take some time, but you can program your remote without the code list.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Need code for phillips remote
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
1helpful
2answers
Phillips pm3s lost code book:
Hope this helps :)
Proscan model 52690
You can get the Phillips universal remote that will work that tv at the following link with free shipping. The phillips universal is one of the best remotes for a universal and easiest to program also
http://servicemanuals.vstore.ca/
5helpful
2answers
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
3answers
Philips TV set PC7225-PC121
JUST GO THE MENU AND PRESS INSTALLATION. SELECT AUTOPROGRAM. AUTOMATICALLY SYSTEM GOES TO DEFAULT MODE.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
