SOURCE: Xerox 7328, error 018-543 Shared name error in server
Prerequisites:
Scan to File is set up in several steps:
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary.
NOTE: The default username is "11111". The default password is "x-admin" and must be entered in lower case letters. If the username or password has been modified or forgotten, contact your System Administrator.
NOTE: A maximum of five file repositories may be configured. Generally, just the default repository is configured for scan to file.
NOTE: The default SMB port is 139. Generally this port number does not change.
SOURCE: xerox workcentre 7328 fault code 062-393
This is a document scanner problem, probably a bad circuit board. (This PN may be 960K00442 but that needs to be verified in your unit)
Short of that, you could reinstall the "IIT software".
A technician could reseat the EEPROM on the IIT board which controls the document scanner. He should also reseat the scanner bar and cables underneath the glass.
Whit
Item, Inc
SOURCE: My Machine Xerox Workcentre 7328
Fault Code 062-393: Scanner Control Board Failure. Power off. wait 1 minute. power on. if still broke call for service - 1-800-821-2797.
SOURCE: xerox workcentre 7328 showing error
Try to Initialize the Spool Disk:
NOTE: Initializing the spool disk will delete all jobs in all queues. This procedure can be used when a corrupt job has caused the printer to stop printing. This procedure can also be used to correct certain machine faults.
CAUTION: Make sure to press the correct buttons all at the same time. An incorrect button combination may delete all customized printer settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: our xerox workcentre 7328 shows fault code 004-346
iot video failure in xerox 7328.code is 04-350
