Https://www.manualslib.com/download/1475945/Honor-8x.html
Download user manual from this link and follow the instructions for pairing.
SOURCE: pairing my bluetooth to my phone
The Passkey for any bluetooth is 0000 so if you put that in it should work.
SOURCE: need code to pair my technocel bluetooth
If you haven't found it yet, use 0000. If this is helpful, please post as such. If it fixed it please post as fixya
SOURCE: Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
SOURCE: Moto H715 microphone doesn't work
Had the same problem and tried all solutions offered on the internet. Mute is off, wire's are not broke, mic is not obstructed.... Called Motorola and they are sending a replacement since the unit is less than one year old. They are sending me the H780 model since the H715 is out of stock. Call 800-331-6456. If you say "agent" you will bypass all the voice prompts.
