Exercise & Fitness Logo
Vanessa Janica Posted on Apr 27, 2019
Question about your pedometer 4x razor - Exercise & Fitness
I recently replaced the battery but the display is still blank, what can I do to get it going?
The device is defective, if it was really high end price wise get it fixed, if not then replace it.
I need a screwdriver and battery holder screw for the 4xx Razor PD4X3-2
Try a jewelry store that does repairs. They'll fix it free because they want new customers.
How do I change the time
Change the time on your pedometer this weekend ...
blog.walkingspree.com > Walkingspree
To change the time on your Omron USB Pedometer press SET and hold it ... AM and PM displayed on your pedometer or it will reset at noon instead of midnight.
[PDF]PEDOMETER - LuckyVitamin
www.luckyvitamin.com/.../Sportline%20Qlip%20Any-Wear%20Pedome...
8. SETTING THE PEDOMETER FUNCTIONS. SETTING TIME. 9. SETTING USER DATA. 10. OPERATING THE PEDOMETER. VIEWING PEDOMETER DATA. 11.
How to Set Up Your Pedometer - YouTube
? 1:51
https://www.youtube.com/watch?v=2Zgh9uDeA4w
Lost my User Manual for my Ozeri 4x Runner pedometer. Where can I get another user manual?
Hi Customer,
Welcome to Fixya!
Please click the link below to download/view the user manual for your device.
User Manual for Ozeri 4x Runner
http://ecx.images-amazon.com/images/I/91G%2BggWgUJS.pdf
Let me know if this helps.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Aldi Crane pedometer. Where can I get instructions?
[PDF]AU4-PF-6LA - Aldi
https://www.aldi.us/.../1.1.14_Crane_Heart_Rate_Monitor_Watch_...
ALDIFitness watch with speed and distance tracking. Pulse measuring without chest strap. Operating instructions. Item No.: AU4-PF-6LA/6LB. Issue: January 2014.
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic InstitutionGetting Started: Setting Up Your Pedometer. Starting your walking program is easy! Use these simple instructions to setup your pedometer and walk your way to ...
Tanita PD637 HANDHELD MOTION PEDOMETER Repair ...
www.dqrkc.com/support/p3651266-tanita_pd637...pedometer/page-4
Tanita PD637 HANDHELD MOTION PEDOMETER - Page 4 - Recent ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 308 Snapshot Pedometer Repair Questions ...
www.dqrkc.com/support/p3642406-sportline_308...pedometer/page-8
Sportline 308 Snapshot Pedometer - Page 8 - Recent Questions, ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 310 Qlip AnyWear Pedometer Repair Questions ...
www.dqrkc.com/support/p1496572-sportline...pedometer/page-8
6helpful
I need setup instructions for a Ozeri 4x motion pedometer. Thanks
Here is a copy of the instructions for the Ozeri 4x motion digital pedometer. I hope this is not too late. Regards.
Timothy Raines
There is nothing on the screen of the pedometer, what ever I press. Do they run on a battery and if so can it be replaced? There's no apparent place to fit a new battery!
Pedometers run on a battery, the type depends upon the exact make and model which you have failed to mention.
Many cheap giveaway pedometers are not designed to have the battery replaced but it's usually possible to carefully prise the case apart if it's not screwed together. Some are glued together in which case you'll need a razor saw: if you have to buy a razor saw then it's cheaper to just replace the pedometer. You'll often find that with cheap disposable pedometers that the batteries actually cost more than a complete new unit with batteries included.
More expensive pedometers will always have a clearly defined battery access point, even if it's just a matter of undoing a few screws to separate the casing..
Sep 21, 2010 • Vacuums
2helpful
2answers
Missing a battery for a Sportline Model 342 Pedometer.
Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
6helpful
Reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
Motorola Razor Vga 4x
Menu->Media Gallery->Videos->highlight the video you would like to delete->press OPTIONS softkey->scroll down to DELETE->SELECT->YES Go ahead and contact me w/ more details if this doesnt help.
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
