However my television menus are in color. Initially I could restore color by turning Off and ON the set but now the pictures are always in black and white. Is this a symptom of a bad Tconn board or something else. re channel search using digital Thank you in advance. or check input or source
Hello Victor, for what you count, that you can not have color in the image of the channels, go through a setting in the menu
Correspond to the choice of color system, it should be in automatic
I sent you the link to download the user manual, on the third page, there are phone numbers to ask about the operation
I hope you have served my comment and that you can enjoy your TV in full color
Greetings Franco Dosil
Hola Victor, por lo que cuentas, que no logras tener color en la imagen de los canales, pasa por un ajuste en el menu
Corresponderia a la eleccion del sistema de color, tendria que estar en automatico
Te envio el link para que descargues el manual de usuario, en la tercer pagina, aparecen telefonos para hacer consultas sobre el funcionamiento
Espero te haya servido mi comentario y que puedas disfrutar de tu TV a todo color
Saludos Franco Dosil
https://data2.manualslib.com/pdf2/44/4377/437633-vizio/m3d550kde_user_guide.pdf?37c0cc4ef66c5c69f086d18b14d0e50e&take=binary
http://cdn.vizio.com/manuals/kb/legacy/m3d470kde.pdf
SOURCE: black and white picture, then color, need to warm up?
If it is still under warranty, go out and take it to the repair shop now! this could turn out to be an expensive repair if ou have to pay for it. Your problem is the digital board with the tuner on it or the processor board for the signals, like the video and such. This could need the entire boards as most maunfacturers do not supply too many repair parts for these sets. Good Luck
SOURCE: Vizio with terrible color
YES. Take it back. Also take your DVD and cables also. Have the store try the tv with their DVD and cables and see if you get the same problems. It it good, then try your cables. Or try your DVD with their cable. It's under warranty now so resolved it now. If you bought by credit card, that may have a brief warranty also.
SOURCE: My little 15
If the format of color system such as PAL/SECAM etc. is not same as that of telecast, you will get picture in black and white.
SOURCE: I have a vizio M3D550KD with no color, black &
I have the same problem, TV signal is black and white (menu has color). I take the HDMI cable out of the problem set and plug it in to a 22" portable, perfect picture, not the cable or the cable box, definitely the TV.
The most of this TV problem is that the inverter transformer built on the main power supply is bad, to fix it, you may replace the transformer , or replace the power supply module.
Testimonial: "Hi, I replaced the power supply module and still sound but I did notice a very faint image on the screen in the dark can't make it out but something is there but any light shining on the screen and you won't notice it. Any other suggestions for this problem"
