SOURCE: B & D leaf hog (blower/vac)
Check an see if a branch or something got caught in the blower an won't let it turn, if it hums that could be the problem
SOURCE: Toro Super Blower Vac will turn come on. Is there a reset button?
Yes there is. Unplug the unit, pull the plastic adapter that converts it between vac and blower off and you'll see the little square reset button. It is recessed into the case. Push it in until it clicks, replace the adapter and plug it in and go. Good luck!
SOURCE: hi--my 395 type 2 with variable speed switch wont
if the motor runs fine ande the drive shaft to the tool just stops turning, look at my previous response
SOURCE: Toro Blower..No power. Like a blown fuse. Does it have a fuse?
I have the Toro 51591 model. Yesterday, mine did the same as yours. I opened up the case and found that a small cylinder had broken off of the switch. So it could be that your switch is the problem. I have been unable so far to find a replacement anywhere.
You should consider using your warranty.
Testimonial: "Thanks. I checked the manual first though and read that the impeller cover if not properly closed will not allow it to turn on. That worked. Thanks"
SOURCE: My windshield wipers will not work on variable
Alarm control unit has a chip in that controls the delay wipers, this chip cost about 2 dollars, but it has to be sodered in. the whole box cost about 200 dollars. It is located behind the glove box on above the right kick plate ive been told. chip can be bought from mouser.
