Start a twitter account about the design and business practices that are used with Canon printer faults. Ensure you get people to follow and comment on their unwillingness to help their customers without charging them a lot. Then send link to twitter account to Canon tech support and ask them to help.
See my other post. You can simply remove the account under general settings and email, then add yours should work, but may need to reset or delete contacts first before adding yours.
Hi maisie benso...
To reset your password you will need to:
Click on Start>Control Panel>User Accounts>Change an Account...
Once you are in "Change an Account" you can delete,change, or do what you need to do with the password.
Please take time to rate me
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME .INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF.INK LEVEL LEVEL ALWAYS SHOW 100 %NO WASTE INK PAD COUNTER MORENO NEED TO WORRY WHILE PRINTING MORE PRINT JOBSnow no more ink cartiledge not recognise problem
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
