Computers & Internet Logo
How to operate becko bim35404xps touch panel - Computers & Internet
2helpful
What will cause a sunroof not to close properly on a 2007 Milan
A lot of thing's , has sensors , switches , a control module , relay's etc....
The roof opening panel is an electronically operated panel that can be opened or closed by pressing a switch located on the overhead console. It also has one-touch open, one-touch close, one-touch vent open and one-touch vent close features.
Roof Opening Panel The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened, closed or tilted by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The roof opening panel has one-touch open and one-touch close features that are activated when the switch is momentarily pressed to the double detent OPEN or CLOSE position. These functions are controlled by the roof opening panel motor/module.
The roof opening panel motor must be initialized whenever the roof opening panel motor has been removed from the roof opening panel system, the roof opening panel assembly has been removed from the vehicle, a new roof opening panel motor has been installed or a new roof opening panel assembly has been installed.
Plus the mechnical parts of it .
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse 33 (20A)
  • Smart junction box (SJB) fuse 12 (7.5A)
  • Circuitry
  • Accessory delay relay
  • Roof opening panel motor and module assembly
  • Roof opening panel switch
My becko dryer stops working when half way through the cycle the plug is plugged into an extension lead and the dryer plug gets warm then switches off please help only 16 months old
FIRST OFF U SHOULD NEVER USE AN EXTENSION PLUG ON A BIG APPLIANCE ITS A FIRE DANGER. HENCE THE HOT TO TOUCH.
YOU MAY HAVE BAD MOTOR WINDINGS OR DOES THE MACHINE START RIGHT BACK UP AFTER SWITCHING OFF IF NOT, THAT IS A SIGN OF BAD MOTOR WINDINGS.
Jan 02, 2017 • Dryers
Ive just got a new becko double gas cooker and everything works except for when i turn on the oven all my hobs keep clicking and sparking anybody no how to sort this out pls
Call your supplier, it may be a fault. Ket them advise you, there should be a warranty under which you can get service or support
Jun 20, 2015 • Ovens
TV will not turn on.
i have a becko 42wlh530hid and it works and it stops working what could b the problem
Becko washing machine
Possible that there is some loose connection or fault with the controller unit. You can remove the panel and check on all connections, check the panel links and if this wont improve the panel board is a suspect.
Can i use my samsung remote to tune in a becko tv
read your instr manual or download from www.fitness.manualsonline.com and proceed according if they suggest that can be use it.
1helpful
My becko wma150w washing machine fills and but the drum doesnt go round
Motor brushes need replacing. check belt tightness too
2answers
BEKO HDTV SCREEN PROBLEM
This may be caused by the LCD Controller (TCON) board. Look for the flat cable running from this board to the right side of the LCD. Sometimes the connection needs to be reseated. Have someone knowledgeable in electronics carefully disconnect and reconnect the cable. Test before reassembling the set to verify its solved. You may have to do this several times if other changes show up.
Grand Canyon Tech
Grand Canyon Tech
