All the universal remotes that I know of can access the Vizio TV since it is well known brand that is now more common than the Sony brand. Check the remote TV menu and user guide for the correct setup.
If you wish for the exact codes, visit the Vizio home page, go to the Support section and search there.
SOURCE: VIZIO REMOTE CODES
JUST TRY THIS PROCEDURE;
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): We could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
SOURCE: Can't find codes for universal remote -- purchased for Vizio TV
Unfortunately, there does not seem to be any truly 'universal' remotes and we have two that won't 'learn' from the originals either.
They should be called 'multibrand' remotes.
Use your Vizio model number of your set and try here:
Remotes
This seems to be the best site but they are also not infallible.
SOURCE: how to setup Directv remote control so it can work with Vizio TV?
Try these...
10864
10885
11756
10178
10442
10700
10856
11178
11265
SOURCE: Do you have innovage remote codes for Vizio VO320E
I don't see Vizio TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page.
Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
