I have opened it up and tried reseating some of the cables as recommended online but that has not made a difference. I have NOT replaced the Y board as some others suggested online. I am not sure whether I should bother as the main problem that people say online is that the screen itself is bad burned out connections to the actual glass screen. What do you think?
Check the display strip. un plug it and fix it
Testimonial: "What is the display strip? The Y board? I already reseated the cables connected to the Y board. Just not sure it is the board. The symptoms seem to indicate it is the panel"
you can guess all day and go broke.
why mess with 10 year old TV.
used boards may be on EBAY but will be not cheap and may be bad.
why not just buy a TV at walfart and call it a day.
your not going to put in in a shop and pay 10x value of TV for labor and parts.
no why does anyone ever do that. (hope, econ101)
why do you think we can guess better than you.
no tools , no schematic, no spares,no service book
and we can' t touch it. nor see your screen.
why?
no need to be a jerk
we r showing where is problem in your product.How i repair from here
I didn't mean you Akbar. I meant the other comments. If someone does not have an answer, then don't comment. I appreciate your comment.
I added a couple of pics here. It shows that the lines are all over the screen but more on the top. What are the chances that it is the board? Or most likely the screen as in this video (ribbon cable to the traces to the screen)?
No board problem..display and also display connectivity problem
Finally i Decide The problem is in Display.Arrange a display and check it
So not worth fixing as the display costs more than a new TV, correct?
It is Your choice. i m only giving problem information.
What would be the fix? Replace the whole screen?
This is very easy purchase a screen. open TV. Remove connections and Remove old display.. fix a new or a used screen if available from any workshop.
I need to try and find another used TV that has a problem but not the same screen display problem. Getting a replacement screen from Samsung is too expensive.
you weight sum time and locate any workshop and get same screen. dont purchase a new its price is very high.
SOURCE: Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
SOURCE: LG 42LB5DF Horizontal lines when first turning on
I got my main board replaced under warranty and this fixed the problem.
SOURCE: Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. [email protected]
SOURCE: Samsung HPR4252 with red horizontal lines accross the screen
I just had my HP-R4252 repaired on 12.05.09 with a similar problem. The picture is covered in horizonal, broken lines and the color is predominately red. They lines are grouped together in large bands across the screen.
The tech replaced the Y-Buffer boards (Up) and (Low) in about 20 minutes.
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY
add a image of Ur TV..i want to c actual problem
Adding three pics
