Hello Julie, what model of Onkio do you have?
What the CBL option indicates is that it is linked to the digital audio input, you have to enter the Onkio menu and select CBL via HDMI
Send the model of your Onkio, to review and confirm what you say
I hope you can solve the problem
Greetings Franco Dosil
Hola Julie, que modelo de Onkio tienes?
Lo que te indica la opcion de CBL, es que esta ligado a la entrada de audio digital, tienes que entrar en el menu del Onkio y selecionar CBL por HDMI
Envia el modelo de tu Onkio, para revisar y confirmar lo que te exprese
Espero que puedas resolver el problema
Saludos Franco Dosil
Testimonial: "Thank you, we have solved the problem by plugging two hdmi from the tv."
Tx sr 383....
Even if i switch the hdmi input output in the tv or the onkyo... the problem follows...
Also, if I plug in my old onkyo, everything works fine...
Hello Julie again, I have asked you to tell me what Onkio model and brand and model of the TV you have, with this data could help you solve the problem, if you use a cable box decoder, also pass me brand and model
I await your comments
Hola Julie nuevanente, te he pedido que me comentes que modelo de Onkio y marca y modelo del que televisor tienes, con estos datos podria ayudarte a que puedads resolver el problema, si usas un decodificador para los canales de cable, tambien pasame marca y modelo
Espero tus comentarios
SOURCE: No Sound in DTV/CBL mode
Ok... I'm still new to the HDMI input. But I'm going to take a shot in the dark on this one.
Please don't rate me poorly for this, by the way. I'd rather you don't rate me at all as I am not proposing a solution.
This is a guess. I'll be honest about that. So here goes... :P
I read through the manual a bit. (Click HERE for the manual.) I started thinking to myself about your situation...and noticed that you seem to be focused primarily on the receiver itself.
What about the Satellite receiver? Have you checked it to see if you might have to manually switch the audio output to your HDMI output? I know you have video and all, but many devices won't assume that you're switching BOTH the video AND the audio outputs. Sometimes you have to manually switch one or the other, depending on how you're connected.
I would check the SAT receiver to see if you have to switch the audio output to go out from the HDMI output on the SAT receiver.
It has always been my experience that when the speaker icons flash on the audio receiver and you're sending a digital signal to it, the receiver is in fact NOT receiving a signal...
...which obviously means that one is not being sent to it.
Please let me know what you come up with. Again, this was just a shot in the dark. But I am curious either way. :)
Let me know!
Cyryl
SOURCE: bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Go to settings on PS3 and sound settings and set them to HDMI.
If the above did not work, try a auto reset, with unit connected. Hold the PS3 power button down and wait until you hear 2 beeps. The PS3 will automatically search your input/output channels.
SOURCE: on a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
