The power indicator is off.
two reason:
1,the mainboard is fault
2,the powersupply is fault
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
SOURCE: BenQ MP610 Multimedia Projector
You have to contact BENQ with the required code numbers to get an
unlock code. No one else can issue an unlock code. If the projector was
stolen, you will not get a code but will probably get a cop at your
door instead.
Contact BENQ in your local country by going to their web pages.
SOURCE: BenQ 8700 Won't Power On
As far as the projector goes, the ac power supply is fused with probably no more than a 7 amp fuse, that would blow before your breaker would if the problem were in the projector. The only thing that could case the breaker to trip would be a defective AC outlet socket or your cord for the projector is bad. I have seen cases where cat's have chewed though the cord and shorted it out and triped a breaker, outside of that if the projector is bad now then your thought of sending to the manufacturer is the best one.
SOURCE: BENQ w10000 makes noise and
hi sir, whether you cecked the color wheel? because once the color wheel motor with issue, make noize too.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
