Question about Video Cameras
JVC mini dv camcorder- when inserting tape, door will not stay close and insert
If I take the type out, it takes several times to push the part in and close the lid
    Master:
  • 373 Answers
You can find a new model here>>www.discountbargainprices.com
Posted on Apr 26, 2019
SOURCE:
  • 10 Answers
SOURCE: how do I close the cassett holder? (JVC GR-D70 comcorder)?
man just try pushing that place by a small support on its lower side. ( imean below... just the opposite side where it is told to "push here". i hope if you didnt broke its locking mechanism, it will work..
Posted on Nov 02, 2007
SOURCE: jvc 700x mini dv camcorder
just got back from a great trip to new york, went to play the video today and there is no sound. Can anybody help/advise? Would appreciate some help as I filmed my friends wedding whilst there so need sound as they want a copy of their big day!!
Posted on Jun 15, 2008
SOURCE: Canon zr300 ejects tapes
Hi guys,
Thank you very much for this solution posting. Really it worked. I was about to buy another one instead of fixing the problem. Because you know how the pain is, to send it factory and getting it repaired.
Once again Thank you.
Posted on Jun 26, 2008
mistersony
  • 320 Answers
SOURCE: JVC BR-DV3000 Mini DV-DVCAM issue
If the problem only shows with Mini DV tapes, it can be a tape guide issue or a mchanism loading problem where the tape is not being properly "seated" into the tape mechanism. You will need to use an oscilloscope to look at the RF waveform coming off the tape to try and figure out where your problem is.
Posted on Nov 08, 2008
SOURCE: Tape ejects on a JVC GR-D275U camcorder but will not autoclose
Threw it in the trash can a bought a Kodak
Posted on Jan 29, 2009
I was getting a message clean heads, so I bought the cleaning mini DV to insert. I pressed the button to open the door where the mini DV tape is and it popped up, but will not pop open to release the...
It sounds like something has jammed the tape door mechanism preventing it from opening. This is a very delicate part of a mini DV camcorder. I would highly recommend taking it to a electronics repair shop where it can be checked out. If you try and force the tape out you will probably cause considerable damage to the tape transport system making your camcorder unusable.
Take Care,
Aug 09, 2010 | Canon Optura 50 Mini DV Digital Camcorder
I cant close the tape compartment
Its a mechanism problem , you need to take it to service centre , will cost about $100 in India
cannot help sorry
Apr 20, 2009 | Sony Handycam DCR-PC101E Mini DV Digital...
Rca CC9360 Mini DV Digital Camcorder
Usually this occurs when the door latch release mechanism is broken. This mechanism is located on the basket where you push the tape in and it's job is to open the tape "door" on the cassette that you insert. Unfortunately, the only fix for this is to replace the cassette basket. I know your camcorder is actually made by JVC, but I don't have access to a manual so I can't supply a part number for you.
Nov 07, 2008 | RCA CC9360 Mini DV Digital Camcorder
Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
Aug 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Feb 11, 2008 | Canon ZR300 Mini DV Digital Camcorder
Error indication E04 eject and re-insert cassette ?
Hi, when you get an E0 type error it is time to take it to a technician.
Oct 13, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
How do I close the cassett holder? (JVC GR-D70 comcorder)?
Oct 11, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
JVC GR-D370 Mini DV Digital Camcorder
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Mar 17, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Video Cameras Logo
46 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
