To purchase a new battery pack for your N2120 torch, you could check with local hardware stores or electrical supply stores. You could also try searching online retailers that specialize in lighting and electrical products, such as Amazon.
In New Zealand, you may also be able to find the battery pack you're looking for at major hardware retailers such as Bunnings Warehouse or Mitre 10. Additionally, you could try checking with manufacturers or suppliers of lighting equipment in the country.
If you are having trouble finding the exact battery pack you need, you could try reaching out to the manufacturer of the torch for assistance or to see if they have a recommended supplier in your area.
yes - call the manufacturer and order a new pack
go to a good battery shop and have the batteries in the pack replaced with better batteries ( about 1/3 saving on the price of genuine pack)
The pack that you clip on is actually a lot of small batteries connected in series to give the desired voltage
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
I would suspect poor quality batteries in the battery pack or memory in the pack from recharging a partially charged pack instead of letting it work to flat condition. New batteries take hours to fully charge so if you just plugged in the charger for a short time before use then the battery pack may nit have been fully charged to start with.
You do not. You will have to replace the entire battery pack. Modern laptop battery packs ave circuits in them that prevent over charging and other nasty habits that batteries used to have. For instructions on removing the battery pack, check HERE. New batteries can be ordered here and here.
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
I too was looking for a battery for the WST1500a. I took the charger and a defective battery pack to BATTERIES PLUS. They rebuilt the pack with new fresh and fully charaged batteries in a short time. The result was good and better then a new battery pack that had been sitting on a store's shelf for 5 years. The advantage is that they are new batteries with a correct charage. The cost was about 75 dollars.
BATTERIES PLUS is a chain and are available in many large cities.
If you need a new "case" for the batteries so you can rebuild the pack, they do have some "packs" on E-Bay listed under BP1600. It's always a "hit and miss" on E-Bay. The problem is that the current vendor lists the BP1600 pack as a Black & Decker part and doesn't know exactly what he is selling. There is no picture of this on the current listing which isn't good.
Try entering the system setup at startup, usually pressing the Delete
or F2 key, it may also indicate whick key to press. Once in the setup
look for a battery utility. Running the utility, if there is one, will
calibrate the battery.
