Stryker endoscopy 988not working .open this machine then transformers is damage . please details transformer voltage and ampair.
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: Samsung M1630 stepdown transformer details
That model doesn't show up at my normal Samsung US parts supplier. Can you post all the numbers found printed on the transformer? One of them should be the Samsung part number. Normally you can look at the voltage rating of the large filter capacitor on the control board and assume that the AC secondary voltage will be about 2V less (in ACrms) than that DC voltage. Now what I'm saying may seem a bit twisted - and it is - but what I mean is this: If the cap is rated at 15VDC, then I'm saying that a secondary voltage of about 13VAC rms should be a good safe level for testing. To confirm this, multiply 13VAC by .635 (assuming it uses a full-wave rectifier) and you get about 8.26VDC. Then allow for about 50% derating by mulitplying the 8.26VDC by 2. This gives you 16.5VDC, which with my generous derating, is pretty close to the caps 15VDC. Then you can remove the transformer and use an isolated Variac(tm) to apply that calculated AC voltage to the secondary connections at the circuit board to see if it powers up. You can measure the DC voltage across the cap as you adjust the Variac(tm), making sure you don't get too close to or exceed the DC rating of the cap. Once you get it working with a main DC voltage of about 50-75% of what's printed on the main electrolytic capacitor, you can start shopping for a sub transformer. It's much easier if it's not a VFD display which would require a separate filament winding, but there's nothing wrong with using a small second transformer for that. You can even mount them both on the chassis and run long leads to the board. As long as the leads are of sufficient gauge, routed and secured well, and protected from nicks, there's nothing worng with that technique. You should make them long enough that if the front panel is later removed for service, the next technician will be able to see the wires before he pulls them out or otherwise damages them. I would also add a varistor on the primary if there's not already one! *grin*
Posted on Nov 01, 2006
  • 317 Answers
SOURCE: Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Posted on Oct 19, 2007
  • 49 Answers
SOURCE: how to test high voltage transformer
#1 Turn off and un-plug the unit for 20 minutes
#2 There is as real risk of electrocuting yourself.
#3 Short the capacitor wit a screwdriver. BE READY for an arc or pop.
#4 You need a special high voltage probe to measure the high voltage. We're talking THOUSANDS of VOLTS here DANGER -DANGER - DANGER!
#4 If you want to try, you first have to DISCONNECT the capacitor from the circuit.
#5 DON'T re connect the power. Measure the resistance of the SECONDARY of the transformer (one lead goes to the capacitor). TELL ME WHAT THE MEASUREMENT IS..
#6 The rectifier could be bad (which is connected to the Capacitor) Usually - if one of th components is bad, it'll blow one of the internal fuses.
Posted on Mar 18, 2008
  • 43 Answers
SOURCE: Logitech x-530 5.1 Speakers Transformer blew
at the cost of some equipment today they are throw away when the dont work and buy new. if its a small transformer you might try radio shack multi volt unit . bring in old transformer so the can match speaker side of wire.
Posted on Dec 07, 2008
supernova278
  • 1932 Answers
SOURCE: Hi I would like to know the input and output
You can directly get the same PCB( 266664-001)from below website
http://www.encompassparts.com/products/?266664-001
Thank you
Posted on Nov 01, 2010
Noisy flyback transformer
It is damaged. no repair to it. Replace it with same number. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site
Jul 20, 2016 | Televison & Video
Stryker x7000 light source. power Fault,i have checked Power Supply component main capacitor fuse and bridge rectifier all is OK but no display and out put,kindly help me please.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 01, 2015 | Televison & Video
POWER VOLTAGE
No. To work with 220V~240v; the device need a step down transformer to be connected in between line and device. The transformer [voltage converter] should be used, otherwise; the unit will get damaged. The step down transformer adaptors can be bought locally. http://electronicshelponline.blogspot.com/
Oct 30, 2014 | JVC GR-D70EK Mini DV Digital Camcorder
WHY H-OUT blowing off
If the Flyback Transformer [FBT] is bad, it can happen. If the DC output voltage from its SMPS is abnormal [higher than normal] this can happen. Contact any service technician.
Sep 03, 2014 | Televison & Video
Onkyo amplifier power transformer voltage details
First of all, did you test the primary and secondary leads for resistance? They all should be from 2-30 ohms max. If they are, the transformer is fine. If they are open, you will need a service manual which may be on-line. If you need more assistance or would like to inquire about repairing your unit, please visit my website at audoserviceclinic.com. Thank you.
Aug 27, 2014 | Audio Players & Recorders
I want to know what is the secondary voltage of transformer inside PC control panel ?
You have not mentioned the details of the machine in question. All you need is to check on the LT ( low voltage side ) of the transformer to find the secondary voltage which will be about 20 to 30 % less than the DC voltage shown on the capacitor on the board. If there are more windings then you can get the primary rewound without any changes to the secondary that must help to solve.
Jan 14, 2013 | Washing Machines
I have a Crosley CR66-PA. It's 120 volts and I
It might have blown the fuse if you are lucky. Otherwise it's likely the transformer failed.
Jun 11, 2011 | Crosley Audio Players & Recorders
Plugged marantz sr8100 into 230V outlet without transformer. Did this likely cause irreparable harm to receiver?
Hello
If you have plugged in to 230AC with voltage settings was 110VAC, the transformer has been damaged already [opend winding]. If the voltage settings was 230VAC itself, there will be no harm to its internal transformer. Anyway, open it, anc check the fuses. In some cases, fule only will blow out, preventing from furhter damages. I'm not sure about it, but check it. If the fuse only has blown out, and there has no harm; you are lucky I should say. OK.
Apr 07, 2011 | Marantz SR8001
Any Whirlpool Microwave Techs out there...Please help a fellow tech
hi mike,
I’m sorry to tell you this but; I wouldn't recommend using a different transformer, even if it's the same size, it could cause serious damage. The HV transformer should only be replaced with the exact replacement part.
Mar 21, 2008 | Microwave Ovens
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
