SOURCE: the process android.process.acore has stopped
please try to reset its because of the software corruption it usually happens in Htc models...
1.Phone turned off, press and hold the HOME and BACK buttons,
and then briefly press the END CALL/POWER button. The reset process will
start after a few seconds.
2. Wait for the phone to finish the reset process and then press MENU.
if it does not solve upgrade to latest firmware
Update to latest version
http://www.htc.com/www/support.aspx
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
SOURCE: LAUNCHER ERROR
it heppened many times to me too
only reinstalling android OS system helped....
on youtube you can find how to do it.... on manufacturer's webpage you can find where to download it
SOURCE: I have a Samsung H819N, and the UI system stops. What is the UI system, and why does it stop?
UI stands for user interface
the only thing that might help you is this video on YouTube:
https://www.youtube.com/watch?v=lyYBZdRJBR8
SOURCE: I have a crystalview xt android tablet or PC and my system UI stopped working
• You need to switch off your tablet
• Then press/hold power+volDOWN+home just keep pressing it
• Then it will switch on with a word start in it let go of the buttons you are holding
• You need to click on the VolDown twice so a recovery mode will appear.
• You need to click power so it will restart to recovery mode
• An android image will appear that has a red exclamation mark
• After which you need to hold down power and then press VolUP
• You need to use volume to scroll and press power to select "wipe data/factory reset"
• Then you need to scroll down again and press power to select "yes-erase all user data" This will now start your tablet to reboot Then it will switch off then switch on again.
